Setup for 12 psi b18c daily need help?
Old Oct 6, 2002 | 08:12 PM
deftones0817's Avatar
Default Setup for 12 psi b18c daily need help?
K look I just need a few helpful answers on my fuel system and for spark
I want to run 12 psi daily and about 20 psi on track. I got what setup for engine internals...just need to figure this stuff out now. so tell me what your running on your turbo b18c
what kind of injectors and what size?
what kind of fuel pump?
who makes some good steel braided fuel lines?
What brand fuel regulator?
What fuel rail?
What spark plugs to use with FI
MSD6AL?
What kind of spark plug wires?
Nology?
Did I miss anything I'm sure I did please throw me some feedback on this...
DEF
Old Oct 6, 2002 | 08:33 PM
avividmemory's Avatar
Default Re: Setup for 12 psi b18c daily need help? (deftones0817)
what are the internals on that b18c? stock? if thats just a stock motor i wouldnt advise running that much boost daily or that much at the track, thats for sure!
Old Oct 6, 2002 | 08:42 PM
Default Re: Setup for 12 psi b18c daily need help? (SpoolinLS)
nope its not stock and I'm not running it yet...i'm try to find what fuel setup to run on my engine I'm building up this is my first time. Basically my whole internals are all crower, except for pistons which are arias 9:1...so what should i use for fuel setup.
DEF
Old Oct 6, 2002 | 08:46 PM
id be careful with those crower cams, ive heard they are weak under high boost...but rumors are rumors...
as for injectors id say 550's would probably be ok up to 15 psi, might want to go with 720s to be safe...
probably range 7 ngk plugs
i like accel plug wires
b/m adjustable fpr
fuel rail shouldnt be a problem
anyone else got ideas?
Old Oct 6, 2002 | 08:48 PM
Thanks for all the help so far...actually i kept the stock cams for now...i didn't order crowers. But I was thinking I won't make much power past 9000 right with cams right so the gsr should be good right? I can use the stock fuel rail?
DEF
Old Oct 6, 2002 | 09:44 PM
jinxproof99's Avatar
New User
What fuel rail?
MSD6AL?
Nology?
DEF
injector size will depend on your fuel management. anywhere from 440's on up. a 255 intank will sufice for your fuel pump. stock fuel rail. ngk plugs. stock or ngk wires. stock spark. no msd or nology wires.
Ant@backyardracing
Dec 7, 2010 08:34 AM
k_bster24
Apr 6, 2004 10:42 PM
deftones0817
Oct 7, 2002 01:25 AM
bronzehatch
Jul 22, 2002 02:27 PM
