what type of signal does the vss on a 95 ls put out?
Old May 3, 2006 | 09:31 AM
rorik's Avatar
Default what type of signal does the vss on a 95 ls put out?
I did a motor swap, 95 ls into an older honda, and I keep getting the code for the vss. It only does it at low speed, like in town. I know my car has the vss signal for the ecu generated in the dash, because it has a cable driven speedo. I'm thinking the integra has a different type of signal from what my speedo cluster is generating, but I should be able to make it compatible with some basic electronics..anyone know what the signal is supposed to look like?
Thanks for any help
Old May 4, 2006 | 05:14 AM
95 integra's Avatar
Default Re: what type of signal does the vss on a 95 ls put out? (rorik)
Im lost, but the 95 has an electronic VSS inwhich you should've swapped out your original VSS if Im not mistaken. Not really a 100% there, but then again I have limited knowledge of the earlier integras.
Old May 4, 2006 | 08:37 AM
rorik's Avatar
you are mistaken..unless you're advocating swapping out the Entire gauge cluster and rewiring my whole dash to be compatible with the electronic vss..F that! I just need to figure out some type of circuit to alter the signal..
Old May 4, 2006 | 08:46 AM
95 integra's Avatar
Default Re: (rorik)
Put in the original VSS, wire it up just like it was previously (yes, this may involve cutting a few wires) and it should work perfectly.
Old May 4, 2006 | 01:50 PM
rorik's Avatar
ok, I guess I found it..6k ohm resistor between the vss wire and 12v..
Modified by rorik at 6:31 AM 5/5/2006
95HondaCivicGrl
Jan 12, 2010 07:32 AM
ZcivicC
Jul 29, 2009 08:54 PM
slowww b18b1
Feb 19, 2004 02:04 PM
horizonteg06
May 19, 2003 09:23 PM
CRAZYLEGED
Sep 26, 2002 06:14 PM
