obd0 pr3 to run poor man's type R allmotor build?
i have a poor man's type R setup in my crx ( gsr block, b16 head , pr3 pistons, skunk 2 IM etc etc..)
my compression is about 11.5 to 1
im curious if there is any way i could just get a chip burned for my pr3 that would run my car well.. or if my ONLY option is to switch to obd1.
i want to make sure i HAVE to switch before i go doing it.. my car is FINISHED other than tuning options , and i figured with my adjustable cam gears and FPR i could use a good basemap and put it on a dyno and a decent tuner could suck some good numbers out of it with just messing with timeing and fuel pressure etc... let me know what you guys think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx »</TD></TR><TR><TD CLASS="quote">i have a poor man's type R setup in my crx ( gsr block, b16 head , pr3 pistons, skunk 2 IM etc etc..)
i want to make sure i HAVE to switch before i go doing it.. my car is FINISHED other than tuning options , and i figured with my adjustable cam gears and FPR i could use a good basemap and put it on a dyno and a decent tuner could suck some good numbers out of it with just messing with timeing and fuel pressure etc... let me know what you guys think. </TD></TR></TABLE>
look for a stage system hondata... i ran it..ancient but works perfect..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx »</TD></TR><TR><TD CLASS="quote">im not having much luck finding one of those, and would my hondata dealership even tune it for me?</TD></TR></TABLE>
church does...
search pgmfi.com i heard theres a program they use to tune obd 0 i think....
church does...
i IMed him.. i don't see what good it will do me when i need a very very close base map because the only fine tuning i can do to it will be with FPR and adjustable cam gears and distributor timing... noone in my area ( kansas city ) messes with tuning obd0 programs
yup, obd0-obd1 harness, chipped obd1 ecu, 4 wire 02, obd1 dizzy. then u can get a nice basmap for it and have it tuned. OR keep the stock PR3 and use a v-afc. not the best option, but if yer area doesnt have any tuners computent with BRE, then the vafc is the way to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">yup, obd0-obd1 harness, chipped obd1 ecu, 4 wire 02, obd1 dizzy. then u can get a nice basmap for it and have it tuned. OR keep the stock PR3 and use a v-afc. not the best option, but if yer area doesnt have any tuners computent with BRE, then the vafc is the way to go</TD></TR></TABLE>
i might consider the vafc2 option since i can get one of those pretty cheap.. what all can be adjusted with a vafc on obd0??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Stop callin it a damn "poor man's type r." Damn I am SICK of that term.</TD></TR></TABLE>
its sick of you too.
</TD></TR></TABLE>LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx »</TD></TR><TR><TD CLASS="quote">i looked into it a little bit and it seems like using a vafc is probably the way to go. . cheap , easy, and lights up and looks nifty
noooooooooooooo!!!
BRE or turboedit.
DrDisco69 does obd0 work send him a pm
</TD></TR></TABLE>noooooooooooooo!!!
BRE or turboedit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***-assin »</TD></TR><TR><TD CLASS="quote">
noooooooooooooo!!!
BRE or turboedit.
DrDisco69 does obd0 work send him a pm</TD></TR></TABLE>
i know i know. but there is noone in my area who will tune with bre or turbo edit... thats my big problem here. im in missouri
noooooooooooooo!!!
BRE or turboedit.
its not like im boosted or anything, or super high compresion, its just 11.5 to 1 with ctr cams.. i don't think i will need anything more than a well made basemap and a vafc maybe..
slow91crx
Apr 17, 2006 04:34 PM
Mentat Ghola
17
Aug 17, 2003 03:22 AM
