Tire Pressure
most standards are 35's....it'll tell you on the tire what the maximum ammount is - put it to that on a hot day (if you put it to that on a cold day, it could expand and put it over the top inflation wise when it heats up...)
look in your owners manual. It's supposed to be 33psi I beleive. I run 35psi. Do not put max tire rated preasure in them your tires will be way over the psi for the car. I had a 95 ex coupe, that I put a set of dunlop fm901's on and made the mistake of putting max tire rated psi in(which was 75psi) and killed the tires in 4 mos.
From: 9/11/01 WTC Never Forget, United States Of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 si hatch »</TD></TR><TR><TD CLASS="quote">look in your owners manual. It's supposed to be 33psi I beleive. I run 35psi. Do not put max tire rated preasure in them your tires will be way over the psi for the car. I had a 95 ex coupe, that I put a set of dunlop fm901's on and made the mistake of putting max tire rated psi in(which was 75psi) and killed the tires in 4 mos.</TD></TR></TABLE>
I dont have the owners manual didnt come with the car
Im gonna go with what Chong suggested 30front 28rear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED’89 »</TD></TR><TR><TD CLASS="quote">
Im gonna go with what Chong suggested 30front 28rear</TD></TR></TABLE>
You should get slightly better MPG if the tire pressure is higher.....
Charri
Jun 23, 2005 01:57 PM
B_1_8_hatch
39
Dec 8, 2002 06:36 PM
