integra type r strut bar in a 91 CRX?
(upper)does it bolt on ? also does a s2000 steering wheel and seats bolt on? does a integra rear upper sway bar bolt on? does integra suspension bolt on?
wow so many question . I APReciate ur answers u uys always help me out.
also wat kind of computer should i be using in wit the type r motor in my crx?
No s2000 parts wont bolt on. You can get the seats to fit with some modified rails. ITR strut bar will not fit. you can use whatever computer you want. What have you done to your car?? Is it obd1?? We have no idea what you can use because we dont know how you have your car wired. The suspension should bolt up and the rear upper bar will not work.
everything is wired up for obd0 i put a b16 computer chiped but the rpm keep jumping up and down. i asked around for integra suspension and got told that it will bolt on but there will be some welding reguired for the front lower control arm bcuz in crx it sits too far from the disc. i also got told that i cud bolt on the s2k steering wheel wit a knut. and the seats need modifieng.
i have a 1991 crx si wit 155k on the body. i recently swaped a jdm type r motor (45k) wit a b16 JDM cable LSD trany and a 4 puck stage 2 clutch on it eveything else is BONE STOCK wit the car got some clean sir rims on 50's on it too. i need a custom muffler done, nothing that farts , but something quite. cant use sir,gsr or type r mufler cuz i got told that theyr different and it wud look ****. i have a full type r cat back exhaust though. im also thinking of geting DC headers but a budy of mine old me THEYR ****. and when u told me that the type r strut bar doesnot fit u ruined my day cuz its soooo sick and its only 100 bux.
The suspension does not need to be welded. you can use the rear trailing arm and on the front you dont need the lower control arm. you only need the disk section. The only reason you would want the integra parts is for the brakes. I am sorry but its very hard to understand some of the things you are trying to say. Your spelling is not the best but I bet we could wrench on that too. LOL
soberstan
20
Feb 10, 2006 08:57 PM
91hondacrx
Jun 14, 2002 10:26 AM
