compression of b16 w itr pistons?
Old Apr 9, 2002 | 04:54 PM
vspec12's Avatar
New User
Default compression of b16 w itr pistons?
what would the compression a b16 w/ itr pistons be...does anybody know what happen to the compression calculator?
Old Apr 9, 2002 | 05:50 PM
eg6ajk's Avatar
Default Re: compression of b16 w itr pistons? (vspec12)
with ITR P73-A pistons = 9.8:1 (basically lowers the c/r) (JDM ITR p73-0 at about 10.2:1, basically stock b16a)
CTR should yield close to 10.8:1 which is what you want for NA setup....
or simply stick with P30 or PR3 pistons, since the ITR/CTR will require some modification to the rod...
Old Apr 9, 2002 | 07:23 PM
allmtr's Avatar
Default Re: compression of b16 w itr pistons? (eg6ajk)
actually, ctr pistons in a b16 gets u about 11:1.
Old Apr 9, 2002 | 07:44 PM
Pat McGroin's Avatar
Default Re: compression of b16 w itr pistons? (allmtr)
yeah it will be same because the heads on the b16 and b18c5's are the same when it comes to the shape, if it were a gsr head that would be a whole different story.
Old Apr 9, 2002 | 08:00 PM
allmtr's Avatar
Default Re: compression of b16 w itr pistons? (JDM Dasilva)
the stroke has some play in it too though, or am i wrong.
Old Apr 10, 2002 | 05:20 AM
1 2 NV's Avatar
allmtr, u r right, the other guys r wrong. its all about the dome. no matter what motor the higher the dome the more compression. 11.1:1 is about right for P73 pistons in a B16.
Old Apr 10, 2002 | 05:53 AM
SpooN Man's Avatar
Default Re: compression of b16 w itr pistons? (hondaatwsu)
b18c heads give higher compression. fact
Old Apr 10, 2002 | 07:13 AM
fowler!'s Avatar
False. P73 will lower. PCT is the only oem piston that will raise compression.
Old Apr 10, 2002 | 04:32 PM
1 2 NV's Avatar
Default Re: compression of b16 w itr pistons? (fowler)
has anyone seen this site? if not u really should take a look. heres the answers to ur compression ?s
Old Apr 10, 2002 | 04:33 PM
1 2 NV's Avatar
https://honda-tech.com/zeropost?cmd=reply&id=1431281
deepbluepentium
May 11, 2006 09:37 PM
KillaB-
Sep 19, 2004 06:01 PM
KillaB-
Sep 19, 2004 10:34 AM
rcurry14
10
Aug 6, 2004 08:36 PM
Bulldogg83
Sep 20, 2003 08:52 AM
