Possible to get code with PM6 and not PR4?
Old May 2, 2006 | 06:48 PM
FOMULA91's Avatar
Default Possible to get code with PM6 and not PR4?
Basically I need to smog my car again and I have a JDM D15B Vtec motor in my 89 HF with a Si intake manifold. I’m currently running it with PR4 ECU, which gives me no codes and it runs GREAT!!!! To smog my car, I was told to use a PG7 or PM6 ECU, so I just bought one today a PM6. The only problem I have is that the PM6 gives me a code. It is either 1 or 10 since it only blinks once and stops a second. My question is “Is it possible to get an code from PM6 and not PR4?” If so, any idea?
I once exchanges the ECU (a PM6) with my other friend CRX a while back to see if his ECU was working or not but it did the same thing, it ran like ****. The idle was kind of low and it seems like it was going to turn off when I try to accelerate from a dead start.
Old May 2, 2006 | 06:53 PM
mntuner2's Avatar
Default Re: Possible to get code with PM6 and not PR4? (FOMULA91)
http://hybrid.honda-perf.org/tech/codes.html
1 is o2 sensor. Intake air intake temp sensor is 10. I would bet on the o2.
Old May 2, 2006 | 07:16 PM
FOMULA91's Avatar
Default Re: Possible to get code with PM6 and not PR4? (mntuner2)
True because when my bro forgot to plug the O2 sensor after we took off the header it ran like **** but that was 10X worst. This one isn't that bad and when I use the PR4, it runs really smooth.
riftonthemind057
Mar 18, 2008 09:56 AM
91GS-R in Vegas
Dec 20, 2007 04:55 PM
draxxus07
Sep 29, 2005 11:35 AM
