This the right way to do compression test?
Old May 2, 2006 | 01:39 PM
standbackimapro's Avatar
Default This the right way to do compression test?
I have an F22
Take out all spark plugs, put Tester in spark plug #1 crank engine 4 times, while holding gas WOT... then just do that for all the cylinders
and to do a wet test you put a table spoon of oil into the spark plug hole, and do the same thing as the other test right?
what is the average Compression for my motor?
Old May 3, 2006 | 04:42 AM
JimBlake's Avatar
Default Re: This the right way to do compression test? (standbackimapro)
Warm up the engine first. Probably want to crank more than 4 times. I crank until the gauge quits increasing, maybe it's 7 or 8 times?
Old May 3, 2006 | 05:07 AM
notoriousB's Avatar
Default Re: This the right way to do compression test? (JimBlake)
crank until the gauge doesn't go up any more like Jim said, not just 4 times. It's best to have a helper crank the car for you while you watch the gauge.
also pull your fuel pump fuse so you don't flood the cylinders with fuel while testing.
wet test same way w/ a capful of oil.
Old May 3, 2006 | 12:54 PM
iam7head's Avatar
Default Re: This the right way to do compression test? (notoriousB)
4 time is not enough
i do a 7 time crank, BUT MAKE SURE YOU DO ALL CYLINDER THE SAME CRANK.
do a double check on the pull just to gather more data.
fuel pump fuse needs to come off
putting a teaspoon worth of oil will locate your problem if you are lossing compression with the ring/valve,etc
Old May 3, 2006 | 12:59 PM
accord-pro's Avatar
135-175 PSI,,,,,,,,,,no more than 28 psi difference between cylinder
Old May 3, 2006 | 01:22 PM
iam7head's Avatar
Default Re: This the right way to do compression test? (accord-pro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-pro &raquo;</TD></TR><TR><TD CLASS="quote">135-175 PSI,,,,,,,,,,no more than 28 psi difference between cylinder</TD></TR></TABLE>
wrong, 10% is the maximun allowable between cylinder.
Old May 3, 2006 | 07:15 PM
Chiovnidca's Avatar
Default Re: This the right way to do compression test? (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">wrong, 10% is the maximun allowable between cylinder.</TD></TR></TABLE>
Actually 28 is more correct if you go by the factory service manual. 10% is easier to remember, and close enough.
Old May 3, 2006 | 10:18 PM
accord-pro's Avatar
you are wrong... read the manual....
sony224422
Dec 5, 2007 06:28 PM
Chris22215
Oct 5, 2005 05:00 AM
Loveless
Mar 31, 2003 10:07 PM
hybridcrx
Jun 26, 2002 07:11 PM
Cyber ITR
Feb 12, 2002 03:19 PM
