map sensor and IAC sensor causing my cold start to run like ass?
just wondering if the map sensor and IAC sensor would cause the cold start on my car to run bad for a few minutes if the sensors themselves are not working right anymore. by running bad i mean misfire/popping and erratic idle for a few minutes then it runs nice. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dodger2940 »</TD></TR><TR><TD CLASS="quote">Would like to know also</TD></TR></TABLE>
we are having the same issue with a h22 and it seems to be a bad iac valve... check continuity across the pins on the iac and there should be no continuity.. if there is its bad.... check signal voltage on the white wire with a DVOM on the map sensor connector and it should be 5 volts... and the yellow and white wire should also be 5 volts..
