engine bay fuse panel: whats the white wire for??
im doing an obd-1 conversion in my crx (got harness from ry-wire) well my e.b. fuse panel was relocated to under the glove box (by previous owner). well i got every thing plugged in except the solid white wire (it has an "eye let"...almost like it would be a ground) it wont reach the fuse box so i need to know: is it a ground wire?? (i dont think so, because it's solid white) and if not could i just extend it? or will that cause any resistance problems? thanks for any help
i relocated that fuse box also, it probally goes to the lower left corner of the box. there are 2 wires that go there both have eyelets to srew them down. pics would help alot in figureing out were they go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxhf »</TD></TR><TR><TD CLASS="quote">i relocated that fuse box also, it probally goes to the lower left corner of the box. there are 2 wires that go there both have eyelets to srew them down. pics would help alot in figureing out were they go. </TD></TR></TABLE> it does go to the lower left of the box, the wire i need is a solid white wire. the wire is comming from the engine bay wire harness(right next to the "power plugs") ill work on finding some pics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood 1 »</TD></TR><TR><TD CLASS="quote">Goes beside the white / red wire.</TD></TR></TABLE>but what is it for?? is it a ground? can i extend it?.....
BoorishId
Jun 25, 2009 04:55 AM
HondaHemi
Nov 27, 2006 04:38 PM
