instrument cluster problems
Old May 2, 2006 | 05:34 AM
civicDX2178's Avatar
Default instrument cluster problems
i got a problem with my cluster it doesnt measure my velocity it does measure my temperature and fuel perfect but the velocity jumps from like 0 to 120 for no reason. i dont know how to fix it i would like some advice before i take it to a shop.
Old May 2, 2006 | 07:50 AM
snatch's Avatar
Default Re: instrument cluster problems (civicDX2178)
Year, model?
Maybe your VSS (Vehicle Speed Sensor) is broken.
Old May 2, 2006 | 11:15 AM
killerformula's Avatar
Default Re: instrument cluster problems (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">Year, model?
Maybe your VSS (Vehicle Speed Sensor) is broken.</TD></TR></TABLE>
Might be the VSS. I have the same problem, replaced the VSS with no luck. I found that the signal from the VSS also runs the cruise control. If your speedometer is not working but your cruise control is then its your cluster.
Another way to check to see if its your cluster is to press the trip odometer reset in and let your finger snap off of it to let it recoil. Sometimes the impact will jar the speedo back into working temporarily. This would prove you've got a speedo cluster problem rather than a VSS problem.
Good luck.
K
Old May 2, 2006 | 11:23 AM
sol2hatch's Avatar
Default Re: instrument cluster problems (killerformula)
i had this problem, many people say it is the VSS, but mine was the cluster itself. Changed clusters and everything works great now. good excuse to get a nice cluster too, SiR or something
Old May 2, 2006 | 11:38 AM
Sol, could you let us know your resource for getting a cluster? Many factory replacement models are hundreds of dollars. Ebay has a slew of used clusters, but given that this problem is so common I'd rather not buy one from ebay. Suggestions?
Old May 2, 2006 | 08:15 PM
sol2hatch's Avatar
Default Re: (killerformula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerformula &raquo;</TD></TR><TR><TD CLASS="quote">Sol, could you let us know your resource for getting a cluster? Many factory replacement models are hundreds of dollars. Ebay has a slew of used clusters, but given that this problem is so common I'd rather not buy one from ebay. Suggestions?</TD></TR></TABLE>
you cant really get one and be 100% sure that it is fine, but a just look at how many miles it has on it. If it has 500,xxx miles on it, it would be safe to assume that you should avoid that one. I actually got mine on EGAY, just look for a reputable seller. Alot of people get JDM ones, but that is dumb IMHO, who wants to read KPH all the time? mine is UKDM, and it is actually in MPH, and it goes to like 150mph, instead of like 120mph, which is purely for looks, but i think it is cool. But just watch for ones with low mileage. Go to a junk yard, Egay, even here on HT. goodluck
Old May 3, 2006 | 06:43 AM
it is a 93 civic DX hatchie thanks for the help
blinger
11
Mar 26, 2024 08:08 PM
mikej94civex
May 25, 2010 05:09 PM
EJ8-Yao
Engine Management and Tuning
Apr 21, 2009 05:28 PM
Random.Hero
Feb 16, 2008 04:40 PM
HULKHATCH10
15
Jul 12, 2005 09:27 PM
