my crazy type s camshaft problem? someone please help?
Old May 1, 2006 | 03:56 PM
darkstar1440's Avatar
Default my crazy type s camshaft problem? someone please help?
alright soo i bought the type s camshafts for my 96 h22a1 and i just want to put them in without replacing any valve train compnents for the fact that its not neccessary..soooo i know i need a belt tensioner i know but which one? and what else do i need anything all i want to do is have everything ready so when i send my car in the shop the work gets all done and they wont be calling me saying i need this and that part what do i truly need for what i want done someone pleeeease help me ive been trying to figure this out for months now..thanks fellas
dustin
Old May 2, 2006 | 04:54 PM
Default Re: my crazy type s camshaft problem? someone please help? (darkstar1440)
???anything???
Old May 2, 2006 | 04:58 PM
helicopter201's Avatar
heard better things about manual belt tensioners than the auto ones.
Old May 3, 2006 | 05:27 AM
flipwhip's Avatar
Default Re: my crazy type s camshaft problem? someone please help? (helicopter201)
yes i would definatly go with a manual tensioner.
Old May 3, 2006 | 05:49 AM
DJ_SaNdOz's Avatar
why not RTFM & just use the parts list for doing a timing belt, but instead of getting the auto tensioner get a manual tensioner.
Old May 3, 2006 | 11:07 AM
GtechPro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkstar1440 &raquo;</TD></TR><TR><TD CLASS="quote">alright soo i bought the type s camshafts for my 96 h22a1 and i just want to put them in without replacing any valve train compnents for the fact that its not neccessary..soooo i know i need a belt tensioner i know but which one? and what else do i need anything all i want to do is have everything ready so when i send my car in the shop the work gets all done and they wont be calling me saying i need this and that part what do i truly need for what i want done someone pleeeease help me ive been trying to figure this out for months now..thanks fellas
dustin</TD></TR></TABLE>
Punctuation is your friend, use it.
Old May 4, 2006 | 01:33 AM
Default Re: my crazy type s camshaft problem? someone please help? (GtechPro)
no puncutation is not my friend and your not either dont respond to my posts if thats all you have to say
Old May 20, 2006 | 12:29 PM
Jago's Avatar
where did you get your cams
Old May 20, 2006 | 12:37 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkstar1440 &raquo;</TD></TR><TR><TD CLASS="quote">no puncutation is not my friend and your not either dont respond to my posts if thats all you have to say</TD></TR></TABLE>
cry about it. good questions with proper english will get good responses
you dont need to upgrade the valvetrain for type S cams. Your stock valvetrain will be plenty strong. Your not goign to be making power beyond the stock rev limiter so valvetrain upgrades are not needed.
Usually the only time you really need to convert to the manual tensioner is when you upgrade the valvesprings. Why? With the added stiffness of the aftermarket valvesprings, the more stress is going to be put on the belt. The more stress on the belt, the more stress on the weak autotensioner.
However, since you are already needing to do the timing belt, go ahead and do the manual tensioner conversion. Its actually quite cheap compared to buying that expensive autotensioner. Also, since you are doing the timing belt, it is recommened to change the water pump while you are there.
There is a howto manual tensioner conversion in this forum.
krayzieboi213
Jul 26, 2008 02:56 PM
Stuartz
May 1, 2007 07:48 AM
fadedline
Jul 26, 2006 06:50 PM
speedbird
Feb 8, 2006 05:35 PM
FoxRiderH22A
Nov 1, 2003 10:35 AM
