what's that switch called that you use a magnet to trip?
Old May 1, 2006 | 03:09 PM
mrdeadman's Avatar
They let me pick
Default what's that switch called that you use a magnet to trip?
does anyone know? it turns on and off with the presence of a magnetic field.
Old May 1, 2006 | 03:13 PM
94_DC4's Avatar
Default Re: what's that switch called that you use a magnet to trip? (mrdeadman)
Is it a magnetic reed switch that you are thinking of?
Old May 1, 2006 | 03:25 PM
mrdeadman's Avatar
They let me pick
Default Re: what's that switch called that you use a magnet to trip? (oemjdmdc)
is it an on/off kind of switch? you swipe the magnet across, on, swipe it again off?
Old Sep 22, 2006 | 08:28 PM
92b16si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">is it an on/off kind of switch? you swipe the magnet across, on, swipe it again off?</TD></TR></TABLE>bump cuz i wana know too
Old Sep 22, 2006 | 09:10 PM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">is it an on/off kind of switch?</TD></TR></TABLE>
Obviously. Would you want a switch that would stay at one setting (on or off) all the time? Then that wouldn't be a switch, would it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">you swipe the magnet across, on, swipe it again off?</TD></TR></TABLE>
When the magnet is close to the switch, it turns on, but when the magnet is removed, it turns off.
Old Sep 22, 2006 | 10:13 PM
92b16si's Avatar
Default Re: what's that switch called that you use a magnet to trip? (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">
When the magnet is close to the switch, it turns on, but when the magnet is removed, it turns off.</TD></TR></TABLE>
no that when you swipe it to one side , lets say to the right the switch turns one, and when you swipe it to the left it stays off.
Old Sep 23, 2006 | 06:02 AM
02 accord's Avatar
Default Re: what's that switch called that you use a magnet to trip? (92b16si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wikipedia.com &raquo;</TD></TR><TR><TD CLASS="quote">A magnetic field (such as from an energized coil around the glass tube or a permanent magnet moved towards it) will cause the contacts to pull together, thus completing an electrical circuit. The stiffness of the reeds causes them to separate, and open the circuit, upon removal of the magnetic field.</TD></TR></TABLE>
http://en.wikipedia.org/wiki/Reed_switch
Old Sep 23, 2006 | 08:52 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know? it turns on and off with the presence of a magnetic field.</TD></TR></TABLE> What do you want to use the switch for? 94
HCJDM1
Audio / Security / Video
Jan 27, 2007 02:03 PM
spintboy
11
Jan 6, 2007 12:31 AM
elwood
Sep 18, 2004 11:37 PM
crewjones
Oct 27, 2003 06:51 AM
allaboutaccordz
Jun 7, 2003 01:34 PM
