To those with obd2 engines in an EG
Old Apr 9, 2002 | 12:29 PM
jdm5ghb's Avatar
Default To those with obd2 engines in an EG
I have a 96 obd2 gsr engine in my 92 cx. i'm getting a check engine light and i know its because i hacked my wiring. well anyways i'm getting it professionally rewired and my question is:
is it better to have the obd2 engine wired for my obd1 computer, or rewire it so i can use my obd2 computer.
is there anything special i need to know
thanks
-Craig
Old Apr 9, 2002 | 12:40 PM
neumonik's Avatar
Default Re: To those with obd2 engines in an EG (jdm5ghb)
to save myself from all the problems I just bought a hondata. It just seems much easier to do it that way.
my .02 cents
Old Apr 9, 2002 | 12:46 PM
hybridcivic93cx's Avatar
Default Re: To those with obd2 engines in an EG (neumonik)
Buy yourself a usdm P-72 GSR Obd1 ecu. It plugs right into your cars wiring harness. Its easier than trying to use an obd2 ecu in an obd1 car.
Old Apr 9, 2002 | 02:08 PM
jdm5ghb's Avatar
Default Re: To those with obd2 engines in an EG (joe-1)
thats whats in there now, an obd1 gsr computer
Old Apr 9, 2002 | 02:14 PM
djay86's Avatar
i know this sounds mad newbie, but what the hell is a hondata
Old Apr 9, 2002 | 04:30 PM
Hayasa15's Avatar
Default Re: To those with obd2 engines in an EG (djay86)
Hondata is a standalone ecu. I have a 2000 b16. I am wanting to put it in my 90 std civic. Should i switch to an obd1 ecu or obd0? I have been told it is too hard to use the obd2 ecu in my civic.
Old Apr 9, 2002 | 08:48 PM
CivicNewbie's Avatar
http://www.hondata.com
Old Apr 10, 2002 | 09:51 AM
92sleepR's Avatar
New User
Default Re: To those with obd2 engines in an EG (Hayasa15)
Hondata isn't exactly a stand-alone. It's a modified Honda ecu with several very usefull additions. It gives you the best of both worlds. The Stand-Alone versatility and the OEM reliability.
As for your set up. Get the wiring fixed and use an OBD1 GSR Computer (or a Hondata modified one) That will be the best for taht particular engine. The Hondata will allow you to change various parameters as you modify the engine so it's a worth while investment.
Mike
Old Apr 10, 2002 | 10:55 AM
JeffS's Avatar
If you can't get an ODB1 P72 to run right, adding a Hondata on top of it is just going to multiply your headaches.
Old Apr 10, 2002 | 06:19 PM
Default Re: To those with obd2 engines in an EG (JeffS)
JDM:
I also have an obd2 motor with an obd1 ecu.. I dont have any driveability problems at all. The car gets 32 mpg mixed driving. I have an obd1 JDM ecu, the mileage is about 3 mph less. If your car is running fine, then leave it alone or chip your ecu.
barraea
Engine Management and Tuning
Feb 1, 2016 09:33 PM
EkCoupeTurbo
May 13, 2013 05:16 PM
Eg->sean
Mar 12, 2013 09:16 PM
mitchell_2kSiR
Dec 30, 2007 09:32 AM
Paulnsx
Jan 12, 2005 01:09 PM
