Whats the differnce between Type-R Pistons...
Old May 1, 2006 | 10:01 AM
Skunk91's Avatar
Default Whats the differnce between Type-R Pistons...
Whats the big difference between type R b18 pistons and regular b18 pistons
Is it the divit in the top ?
Im buying a b18 for my rex and it comes with (type-R) Water pump oil pump and pistons but my main concern is the pistons
any responses are appreciated
Old May 1, 2006 | 10:18 AM
CRX Toad's Avatar
Default Re: Whats the differnce between Type-R Pistons... (Skunk91)
Please remember there are several B18's LS, GSR & ITR then to further muddy the water there is USDM and JDM so there is no "regular" B18.
USDM LS has -3.20CC dome
USDM GSR has -0.60CC dome
USDM ITR has 3.64CC done
Old May 1, 2006 | 10:26 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Whats the differnce between Type-R Pistons... (CRX Toad)
It basically means your motor have high-compression. Your main concern is going to be the need to run premium fuel only (91 octane). If you don't run 91 octane, the best thing that will happen is your computer retard your ignition timing & you won't make max power (if you have knock sensor). The worst case would be damaging the motor from detonation if you don't have a knock sensor...
green eyed bandit
Jul 1, 2007 07:18 PM
dsosa51
Jun 8, 2004 07:51 AM
N1 Andy
Apr 12, 2004 03:26 PM
phantoman
Nov 21, 2002 12:09 PM
keys
May 16, 2002 10:55 PM
