blown head gasket (how to head removel)
Old May 1, 2006 | 08:27 AM
turbo gsr
Guest
Posts: n/a
Default blown head gasket (how to head removel)
already did a search. blew my head gasket on the dyno pushing 24 psi of boost, now i have to replace the gasket, any tips or diagrams on how to make the process a little easer would be great thanks
Old May 1, 2006 | 08:38 AM
Goodbye My Love's Avatar
Default Re: blown head gasket (turbo gsr)
What year is your DC? I'm curious because I plan to boost mine soon...what modifcations did you do to the car?
Old May 1, 2006 | 09:44 AM
AK94GSR's Avatar
Default Re: blown head gasket (Todo Driving School)
SEARCH AND U WILL FIND
Old May 1, 2006 | 02:08 PM
Wayne_Curr's Avatar
Default Re: blown head gasket (AK94GSR)
Helms manual is your friend. You dont need a writeup if you have the manual. http://www.hondahookup.com
Old May 1, 2006 | 02:15 PM
LordAphotic's Avatar
https://honda-tech.com/zerothread?id=1404959
Old May 2, 2006 | 08:22 AM
turbo gsr
Guest
Posts: n/a
Default Re: (LordAphotic)
perfict thanks
Old May 2, 2006 | 08:30 AM
crx_88_si's Avatar
u run a boosted teg @ 24psi and dont know how to remove the head ??
Old May 2, 2006 | 08:59 AM
turbo gsr
Guest
Posts: n/a
Default Re: (crx_88_si)
just looking for tips to make it easyer , already did it took not even 2 hrs
Old May 2, 2006 | 10:33 AM
fergy016's Avatar
buy a helm's
Old May 2, 2006 | 12:18 PM
turbo gsr
Guest
Posts: n/a
Default Re: (fergy016)
is that the one that has like over 1000 pages and has pretty much anything you need to know about the car including torque specs?, because iv seen those and wanted to buy one but their like 90 bucks.
Old May 2, 2006 | 12:52 PM
Integra Integra's Avatar
Default Re: (turbo gsr)
Remove Valve Cover
Remove Intake manifold (clean off old gasket w/ Gum Cutter)
Remove the cams and the intake/exhaust lobes dont mix em up or else it will suck when you put em back (TIP: LABEL A BOX INTAKE on one side and EXHAUST on the Other then tape em down so they wont get lost.
Remove the head studs
remove head
Resurface head and while your at it replace valve seals to prevent oil burning down the road
Old May 2, 2006 | 02:08 PM
import810's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">u run a boosted teg @ 24psi and dont know how to remove the head ?? </TD></TR></TABLE>
ehh tahts what im saying
Old May 2, 2006 | 02:25 PM
Wayne_Curr's Avatar
Default Re: (import810)
mkay, removing the head isn't a challenge, reinstalling everything is the challenge.
Old May 2, 2006 | 02:54 PM
SlamminS85's Avatar
Default Re: (Wayne_Curr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne_Curr &raquo;</TD></TR><TR><TD CLASS="quote">mkay, removing the head isn't a challenge, reinstalling everything is the challenge. </TD></TR></TABLE>
yeah exactly, give me a blow torch, saws-all, impact hammer, grinder, and a dremil and i can get the head removed from the block
Old May 2, 2006 | 04:03 PM
DC2 Mang's Avatar
Default Re: (Integra Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra Integra &raquo;</TD></TR><TR><TD CLASS="quote">Remove Valve Cover
remove head
Resurface head and while your at it replace valve seals to prevent oil burning down the road</TD></TR></TABLE>
dont forget the timing belt might as well change it while youre at it
Old May 2, 2006 | 07:43 PM
1990DA's Avatar
I smell bullshyt.
You probably blew the headgasket doggin out mommy's hatch on the way home from the library... and now you have to fix it.
Old May 2, 2006 | 08:00 PM
fergy016's Avatar
http://www.helminc.com
$60 when I bought mine. It will have alot about your car. Removing the head is a bit of work.
Integra Integra has the right idea.
The cams wont seat right if you install them incorrectly because one drives the distributor with a slit on the end.
Pulling the head means you gotta remove the timing belt, and that isn't something you wanna reuse.
Old May 2, 2006 | 08:45 PM
Ruben19's Avatar
only takes me 30min or less to remove my head.
Old May 2, 2006 | 11:31 PM
sik96teg's Avatar
Default Re: (Ruben19)
why remove the intake mani jus to replace a head gasket save time and money buy just leaving it on
Old May 3, 2006 | 12:13 AM
92gsrteg's Avatar
ive taken off my head 3 times already and now i can do it in less than an hour and remember all the torque specs and tightening sequences for all the bolts in the head, its all really easy, no hard parts just long tedious parts like torqueing the head studs down in sequence, disconnecting all the coolant lines that run to the head and intake manifold, and most of all, making sure the cam gears and crank pulley are all on top dead center together and gettin the timing belt on while keeping them centered.
I used to take off the intake manifold first and realized that its easier to just keep it on the head the entire time, this way you wont need to replace the intake manifold gasket either(unless ur a lucky bastard and have a hondata gasket or somethin similar).
Good luck, no real help hear just had to share my view, i used a manual the first time though.
Old May 3, 2006 | 07:16 PM
.Eddie's Avatar
Default Re: blown head gasket (92gsrteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 &raquo;</TD></TR><TR><TD CLASS="quote">yeah exactly, give me a blow torch, saws-all, impact hammer, grinder, and a dremil and i can get the head removed from the block</TD></TR></TABLE>
Why bother, just get (4) M100's and drop them in where the spark plugs would be and light those bad boys. I swear that head will be off in in less than a second
Old May 3, 2006 | 09:52 PM
SlamminS85's Avatar
Default Re: blown head gasket (killerb20zallmotor)
to get them to blow at the same time would be a challenge though
how bout two half sticks in plugs 2 and 3's holes
shytdoode
11
Dec 29, 2009 01:31 PM
headpot420
Dec 27, 2008 12:52 AM
actionfigure
Feb 8, 2007 12:40 PM
DownRightPinoy
Jun 9, 2003 03:39 PM
get wet racing
Dec 7, 2002 09:29 AM
