B-20 /TYPE-R - HEADS
Old May 1, 2006 | 07:41 AM
Type-Rik_83's Avatar
Default B-20B4 /97 ACURA TYPE-R - HEADS
IS THIS A GOOD SET UP . B-20 WITH TYPE -R - HEADS .????
Old May 1, 2006 | 07:42 AM
Dave_B's Avatar
Well if you can get ITR headS on it, LMK. I was baffled to see the F20 with a CTR trans. Let's see what you can do...
Old May 1, 2006 | 07:43 AM
Default Re: B-20 /TYPE-R - HEADS (Type-Rik_83)
SORRY NOT PRELUD , CR-V ...
Old May 1, 2006 | 07:50 AM
WHAT YOU GUYS THING ? IS IT WORTH IT ??
Old May 1, 2006 | 07:58 AM
COULD THA B-20 CRANK HANDEL UP TO 8200 RPM ??
Old May 1, 2006 | 08:29 AM
94rs-turbo's Avatar
its not the block that u have to worry about as far as the revs, its the head that matters on that part but,.......... the b20 block is weak the sleeves are thin and can not handle much power. if all motor and the ls/vtec set up is done right it will do good if u half *** it ..... well it will fail
Old May 1, 2006 | 08:34 AM
clayton bigsby's Avatar
Default Re: (94rs-turbo)
i have had a B20 with a gsr head with R springs retainers cams and skunk2 maifold and i used to rev it tell 8500 with no problems.
but like 94rs-turbo stated B20's do have very thin sleeves and they will brake on if you over rev past that.
Old May 1, 2006 | 08:49 AM
ekim952522000's Avatar
Default Re: (clayton bigsby)
some advice take off your caps lock and learn to use the <U>search</U> button
Old May 1, 2006 | 08:53 AM
WELL BOUT IF YOU SEND THE CRANK TO GET BALANCED&gt;FULL BALANCED ,PISTON,FLYWHEEL RODS, ECT.. WOULD THAT HELP A LOT?
Old May 1, 2006 | 09:04 AM
Dave_B's Avatar
May I suggest the all motor forum. Them and the Hybrid forum may be able to answer your questions a little bit better.
jeffnerette
Dec 14, 2009 08:01 PM
TurbodTegSfaria
Oct 5, 2009 03:36 PM
rare_db2
32
Jul 27, 2007 01:10 PM
trashkilla
May 15, 2004 12:37 PM
SIReg9
Dec 15, 2002 04:51 AM
