Rebuild....
Ok im burning alot of oil, what are the possible causes? My guess is rings and stem seals but is there anything else that could cause this problem? When i take my head in ill get the seals replaced and also bring the block in to get spec'd. Then all i need to do is hone it, that is if its to spec, slap the new rings in and break 'er in. The weird thing is that my motor is 200 psi all around. When i start my car itll smoke 10 seconds after starting it, then when its warm it smokes when im 5-6+ rpm. Sounds like they both need replacing but what else should i look for?
Sassafrass
20
Jul 18, 2006 07:06 PM
mrbsponge
Aug 22, 2004 07:53 PM
