Best tranny for 92 ls?
Old Apr 30, 2006 | 07:58 PM
Rebel_67's Avatar
Default Best tranny for 92 ls?
i have a 89 crx with a 92 ls motor and tranny, but i need a new transmission and i am not sure what kind i should by. Would any B-series transmission fit? What do you guys think would be the best i can buy. I have about $600. also i want to put a-vtech head on it but dont know what type of head to get. As you can tell i dont know much about hondas/acuras but i am trying to learn.
Old May 1, 2006 | 04:54 AM
Rebel_67's Avatar
Default Re: Best tranny for 92 ls? (Rebel_67)
Anyone?
Old May 1, 2006 | 04:59 AM
IHTFP's Avatar
any bseries tranny will fit, but youre probably limited to a 90-93 integra cable tranny if you have the mounts for a cable tranny...94+ are hydro trannys
theres tons of threads about trannys in general..
look for a b16 or a 92-93 gsr ys1 tranny...
Old May 1, 2006 | 02:04 PM
Rebel_67's Avatar
Default Re: Best tranny for 92 ls? (IHTFP)
well my transmission says YS1 on it but i wanted a knew one because it is cracked on the bottom and it leaks. the guy i bought it from put J-b weld on it but it still leaks. i didnt know it was cracked until i changed the clutch.
Old May 1, 2006 | 02:19 PM
IHTFP's Avatar
all 92-93 trannys are ys1...just the gsr have shorter gears...
Old May 1, 2006 | 02:26 PM
watsvtecEK's Avatar
for $600 you can get a cable jdm b16 tranny with lsd. look around in the classefides.
Old May 1, 2006 | 08:10 PM
89a6T's Avatar
Default Re: Best tranny for 92 ls? (D 2da A9)
for $600 you should be able to get your tranny rebuilt. look for a blown one for casing parts to repair yours and have it freshened up so theres no guessing in whats up with the one your gonna get. somebody could tell you its a mint b16 cable tranny with lsd and 40k miles...you put it in and theres no 1-3rd or lsd and its a ls. just my 2 cent anyway.
Old May 1, 2006 | 10:50 PM
importdude2000's Avatar
jdm ys1 with lsd
or usdm/jdm ys1 gsr/b16 one
perfect......only thing is cruise high rpm and lower top speed
Old May 1, 2006 | 11:54 PM
ecks_fourttwo's Avatar
i hate when im too late posting and someone else gives the answer i was going to give...oh well.
here it is anyways... ys1 w/lsd
Old May 2, 2006 | 12:12 AM
SlamminS85's Avatar
Default Re: (ecks_fourttwo)
just run it without a tranny... attach the clutch directly to the drive shaft... and prepare to always turn left
Old May 2, 2006 | 02:47 PM
Rebel_67's Avatar
Hey ecks i noticed in your sig it had ls v-tech. what all woud i have to do to do ls v-tech on my car. I know i need a v-tech head but what else????
Old May 2, 2006 | 09:16 PM
watsvtecEK's Avatar
Default Re: (Rebel_67)
VTEC
Old May 3, 2006 | 05:31 PM
Rebel_67's Avatar
Default Re: (D 2da A9)
I know that but what all do i need to do to the motor to connect the v-tech and the v-tech head, because i know it just dont bolt right up.
civiceagle2
May 4, 2013 02:17 AM
christion
Feb 4, 2008 03:17 PM
KiLlInG 562
Apr 5, 2004 08:29 PM
tncivic-dvsb
Oct 30, 2003 07:29 PM
