Quick please how to diy air fuel gauge
anyone know of a site with a nice write up of how to install an airfuel gauge?? autometer... into a 00 civic dx??
thanks in advance.. i did a search and didnt find anything..
thanks
thanks
Autometer Purple goes to White wire at primary O2 sensor or at pin # D7 of the PCM (ECU).
http://www.autometer.com has all the tech info you needed.
That thing is not of any use if you actually plan on using it to see what your actuall air/fuel ratio is and plan to tune with it.
Step up to the plate and buy a real wideband air/fuel ratio gauge/sensor and get a air/fuel ratio meter that will actually tell you whats going on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">That thing is not of any use if you actually plan on using it to see what your actuall air/fuel ratio is and plan to tune with it.
Step up to the plate and buy a real wideband air/fuel ratio gauge/sensor and get a air/fuel ratio meter that will actually tell you whats going on.</TD></TR></TABLE>
