radio ON w/ no keys
Old Apr 30, 2006 | 02:04 PM
BLUE EH3's Avatar
Help we my pennies
Default radio ON w/ no keys
is there any way to rigg up a way , so that u can leave ur radio on and take ur keys with you , so ur car doesnt get stolen??
Old Apr 30, 2006 | 02:17 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: radio ON w/ no keys (BLUE EH3)
S I M P L E........just wire up @ the radio... the "ACC" power wire onto the "battery (12v constant)" power wire. In other words....DO NOT USE THE "ACC" WIRE FROM THE CAR!!! If I'm not mistaken the ACC is red and the battery is yellow. DON'T FORGET TO TURN YOUR RADIO OFF OR YOU'LL END UP WITH A <U>DEAD BATTERY</U>.
Old Apr 30, 2006 | 02:21 PM
1992HB's Avatar
Default Re: radio ON w/ no keys (NVturbo)
how will that stop someone from stealing your car?? just because you left it on doenst mean they wont mess with it. what about the times the radio isn't on?
Old Apr 30, 2006 | 02:33 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: radio ON w/ no keys (1992HB)
1992HB,
He was referring to the fact that he wants his stereo system on but to NOT have the keys in the ignition hole.
Old Apr 30, 2006 | 06:48 PM
BLUE EH3's Avatar
Help we my pennies
whats the acc wire?
Old May 1, 2006 | 03:05 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">whats the acc wire?</TD></TR></TABLE>Look on the back of your radio...it's usually the red wire @ the harness (radio). That wire is 12V ACC which means it only comes on when you turn your key.
Old May 1, 2006 | 04:01 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 2:27 PM 11/16/2006
Old May 1, 2006 | 04:11 PM
EeeJayEight's Avatar
Default Re: radio ON w/ no keys (schlit)
isnt ACC stand for accessory and is only on when the key is on the first click??/
you could set up a relay if you wanted to or just tap the constant 12v that powers things like the memory for station presets or clock
i have done this before, but i dont know if it is safe so, do so at your own risk
Old May 1, 2006 | 04:12 PM
Default Re: radio ON w/ no keys (EeeJayEight)
nvm.. i just red what was going on... the above description from whoever was saying not to use the ACC and use the 12v is correct...
Old May 1, 2006 | 04:15 PM
NVturbo's Avatar
O.G. triple O.G.
schlit,
It does work...if you combine the red and yellow wire of the radio and wire them to the 12v battery power wire of the car harness. This will enable you to listen to your stereo without the key in the ignition.
Old May 1, 2006 | 06:03 PM
postman's Avatar
hell yeah had mine like that for years now
Old May 1, 2006 | 06:18 PM
Ross 2.0's Avatar
In a Junkyard near you.
I did that without splicing the 1st wire.
Just get a jump box (portable car jump starter)
Get a male to male cigarette plug and plug the jump box to the car.
And then you have radio with no keys.
Old May 2, 2006 | 10:36 AM
y2kferari's Avatar
Default Re: radio ON w/ no keys (postman)
listen to NVTurbo, my civic is set up so I can do that same exact thing. DO what he said, combine the 2 wires and battery and that's it. also, like he said, turn your radio off before you leave your car so you would kill your battery, if you leave it on for too long, lol.
Old May 2, 2006 | 12:29 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: radio ON w/ no keys (y2kferari)
MooGoCow3,
There is no need to go out and buy a portable battery starter in order to do this safely. Save that money for other things...such as oil changes and miscellaneous parts.
y2kferari,
I actually did this wiring by mistake at one time....and I realized that my radio didn't shut off when I took out the key. Sometimes, little mistakes can actually help you out later on.
Old May 2, 2006 | 01:54 PM
y2kferari's Avatar
yeah, my cd player was shorting out for some reason and I NEED my music so I just reconfigured the wires as so and no problems since. It's actually funny, accidental I geuss would be the discription. I was at a show one time and had my subs hitting and all, and a guy jumped in and tried to ride off with my car, assuming the keys were in the ignition. Well, he and his idea got kicked the * out real quick. save me a few times I would say, lol. good luck
Old May 2, 2006 | 02:42 PM
Relic1's Avatar
1-radioshack #275-625 ($3.79) or any other SPDT switch capable of holding 3amps @ 12V.
switch wired like this
constant power - radio ACC input - normal ACC power.
This will make it so when the switch is in one position and it will function normally so you don't accidently leave your radio on at night.
Flip the switch and it will be on all the time.
ZOMBIEKILLER
Audio / Security / Video
Feb 24, 2008 07:14 PM
j_DC2_m
Apr 14, 2007 04:32 PM
2DoorBandit
May 7, 2006 07:48 PM
4runner
Jun 10, 2005 03:36 AM
4runner
Jun 9, 2005 11:38 PM
