Component speakers up front
Old Apr 30, 2006 | 11:41 AM
Hairy Gorilla's Avatar
Default Component speakers up front
Has anyone here installed a new set of component speakers in the front of an integra? Do you have any recommendations on where to leave the crossover? Did the tweeters fit in flush? Did you have to do much fabrication yourself?
Also, what components would you recommend? I just got an Alpine 9857 headunit installed.
Thanks
BTW, 99 GSR
Old Apr 30, 2006 | 11:45 AM
Vtecfool's Avatar
Default Re: Component speakers up front (Tim Maryak)
bump, would like to know also...
also, you might want to try posting this in the audio threads
Old Apr 30, 2006 | 11:51 AM
.brian.'s Avatar
Default Re: Component speakers up front (Vtecfool)
my 97 gs came stock with separates up front. you could look for doors that come with the tweeter holes already there
example (note you do not have to buy JDM ITR doors to have tweeters, just using as an example)
http://www.passwordjdm.com/pro...D=214
Old Apr 30, 2006 | 11:59 AM
Vtecfool's Avatar
Default Re: Component speakers up front (.brian.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">my 97 gs came stock with separates up front. you could look for doors that come with the tweeter holes already there
http://www.passwordjdm.com/pro...D=214</TD></TR></TABLE>
don't all gsr's comes with tweeters?? I have stock tweeters in my gsr.
Old Apr 30, 2006 | 12:02 PM
Yeah i've got tweeters that came stock. I've just been told some aftermarket tweeters don't fit in the stock holes without some fabrication and altering.
Old Apr 30, 2006 | 12:15 PM
.brian.'s Avatar
sorry about that
i think the stock tweeter size minus mounting hardware is 1.25. i am looking to confirm this, so don't hold me to it until i can do so.
Old Apr 30, 2006 | 01:03 PM
cm zak's Avatar
All tegs came with tweaters...
Old Apr 30, 2006 | 01:10 PM
.brian.'s Avatar
Default Re: (cm zak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak &raquo;</TD></TR><TR><TD CLASS="quote">All tegs came with tweaters...</TD></TR></TABLE>wrong.
taken from this thread
https://honda-tech.com/zerothread?id=505252
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">My SE with leather doesn't have the tweeters, my interior is tan.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">The RS and LS doors came without tweeters. LS had the optional radio/cd upgrade which came with tweeters installed.
I had an LS without the tweeter holes. Then i cut holes to install MB Quarts. They Rock!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JR96Teg &raquo;</TD></TR><TR><TD CLASS="quote">My '96 LS Special came without tweeters but has leather, the doors are black with gray leather.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingJeff &raquo;</TD></TR><TR><TD CLASS="quote">my 95 ls doesnt have tweeter. Anyone wanna sell me there tweeter grills??</TD></TR></TABLE>
furthermore, here is a thread about a guy installing tweeters in his DC where there are no stock tweeter locations
https://honda-tech.com/zerothread?id=1562708
Old Apr 30, 2006 | 01:25 PM
suzawa94's Avatar
Default Re: (.brian.)
i installed infinity kappa components (60.7cs). for the mid you have to use the small backing/spacer to mount it cleanly. it's depth is 1 7/8" i believe. as for the tweeter, my car is a gs-r so it had the tweeter holes. i just pressure fitted the tweeter in the stock location. it fits pretty snug
Old Apr 30, 2006 | 01:35 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Was I the only one without tweeters then ??
There shouldn't be much to fitting in the comp set,
take the doorpanels off if you haven't already and start laying stuff out.
Old Apr 30, 2006 | 04:00 PM
crf450ex's Avatar
Default Re: (FlatBlackTeg)
you can put the crossover inside the door. I have alpine type r componets, and i dont remember exactly were i put them, but i seem to remember a small black like compartment on the inside of the pannel, i think it was sum kind of support..... But it fit right inside of it.
Old Apr 30, 2006 | 04:07 PM
Default Re: (crf450ex)
Cool. I've taken the door panel off but never messed around with a crossover. With my aftermarket headunit, how are the stock tweeters/mids being powered? Is there a crappy stock crossover in there?
From my minimal knowledge, when you get an aftermarket component system does it run like this...you run the wire from the headunit that goes to the front left, for instance, to the crossover first, then it sends out two signals, one signal for the mid and one for the tweeter. Is this right?
Old Apr 30, 2006 | 04:52 PM
96 GSR-T's Avatar
Default Re: (Tim Maryak)
I got MB Quart Components all the way around in my car, the tweeters fit find in the factory location and i just left the crossovers in the bottom of the door. Powered them with an Apine V12 4ch
Modified by 96 GSR-T at 11:33 PM 4/30/2006
Old Apr 30, 2006 | 06:44 PM
93_teg_CT's Avatar
Default Re: (96 GSR-T)
I put Alpine Type S crossovers in the front of my 93 LS. They're being powered by a V12 alpine amp. Sounds real nice. Especially with the Alpine coaxles in the back and the alpine head unit.
I could take more pics if needed...
Old Apr 30, 2006 | 07:13 PM
Tonyl507's Avatar
Default Re: (93_teg_CT)
I instaled a set of pioneer components in my GS last week.
Had to mod the woofer part by cutting the plastic backing off with a dremal b/c the new speakers were much bigger: so they sit alot deeper. (you could have also used a MDF spacer i guess, but then the speaker might hit the cover when it bumps)
Tweeters fit fine in stock location, and i just put the crossovers inside the door with some zipties/glue and some padding- there not going anywhere
powered em with a pioneer 600w 4 channel amp
They sound much better then the stock ones, I never relized how much the stock componets suck until now
Old May 1, 2006 | 08:36 PM
Default Re: (Tonyl507)
Cool. I think I might go without an amp for the speakers. I've got a good alpine head unit so i'm hoping it will have enough juice to power them. I'm not looking to play my music crazy loud. I am installing a amp/sub for the system as well
kelviiv
Audio / Security / Video
13
Oct 16, 2018 03:54 AM
russianroulette
11
Sep 16, 2004 06:59 AM
dubbs
Mar 9, 2004 06:24 PM
pnthr30
Oct 6, 2003 11:10 AM
