b18a1 tranny wont come off
Old Apr 30, 2006 | 11:26 AM
Mistermark's Avatar
Default b18a1 tranny wont come off
i got my hands on a b18a1 from a 90' teg, it has a Auto tranny, which i wanted to take off, and for an odd reason the son of a b*tch isnt coming off, all the bolts are out, the starter is off, and btw the motor and tranny are on a crane (not in the car)
theres not even a gap between the seal yet. i tried hitting it still nothing, u think its just the seal thats super stuck, i know i didnt forget any bolts. thanks, any help would be great
Old Apr 30, 2006 | 11:31 AM
Danziver's Avatar
Default Re: b18a1 tranny wont come off (Mistermark)
Double check to make sure you got all of the bolts out and then use a pry bar.
Old Apr 30, 2006 | 11:38 AM
Mistermark's Avatar
yea im gonna check again for the 100th time, and the thing is i cant get a pry bar or screwdriver anywhere cuz theres no gap or and even when i get some grip it doesnt budge
anyways it may just be my shitty tranny stuck, i dont wanna bother people, i just have to beat the **** out of it
Old Apr 30, 2006 | 01:28 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (Mistermark)
There is no real "seal" on the trans to block,
you got that arm going from the bottom of the block to the trans also right?
Old Apr 30, 2006 | 01:40 PM
jthm's Avatar
You are probably over looking a bolt. Happens all the time.
Old Apr 30, 2006 | 04:04 PM
kpop's Avatar
Default Re: (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">There is no real "seal" on the trans to block,
you got that arm going from the bottom of the block to the trans also right?</TD></TR></TABLE>
yeah there is no seals from the tranny to the block.
use a pry bar or a flate head and hit it with a hammer to open a little crack
see if that works.
Old Apr 30, 2006 | 05:26 PM
blkb18's Avatar
Did you take off the torque converter bolts? Unlike a manual trans, autos have bolts going from flywheel to torque converter. You access these by taking off lower dust shield, spin the trans to access, there should be about 6 of them.
Old Apr 30, 2006 | 05:38 PM
Hype-R Stalker
Default Re: b18a1 tranny wont come off (blkb18)
the converter is attached just like the clutch, and pressure plate are attached,
In turn being you wouldn't have to unbolt it til the trans is off.
Old Apr 30, 2006 | 05:44 PM
blkb18's Avatar
Default Re: b18a1 tranny wont come off (FlatBlackTeg)
its a hell of alot easier to unbolt the tc bolts first, especcially if the engine/trans is still in the car, it would have to pull perfectly strait out about 3 inches for the tc shaft to come out.
Old Apr 30, 2006 | 05:49 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistermark &raquo;</TD></TR><TR><TD CLASS="quote">and btw the motor and tranny are on a crane (not in the car)
I guess you missed that part?
Old May 1, 2006 | 02:23 PM
Mistermark's Avatar
ok ok i feel dumb, i have to unbolt the torque convertor, im used to opening up manual trannys. stupid auto.
Old May 1, 2006 | 02:45 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistermark &raquo;</TD></TR><TR><TD CLASS="quote">ok ok i feel dumb, i have to unbolt the torque convertor, im used to opening up manual trannys. stupid auto.</TD></TR></TABLE>
thats not whats holing it on, i took my auto tranny of with out removing the torque converter. id say you forgot a bolt (lower tranny bolt, the 2 t-bracket bolts, or you forgot to remove the drive plate cover). once all the bolts come loose the tranny will seperate a little bit. good luck
duquetco
Jan 27, 2008 03:29 PM
SECURITY
11
Sep 8, 2005 12:13 AM
Unjockable
20
Nov 10, 2003 02:36 PM
Rpc07
Aug 28, 2003 10:10 PM
Heinz57
May 26, 2003 12:34 PM
