Integra dash wiring one wire left (searched found nothing about my problem)
ok i went the easy route and i use the integra harness with the civic clip but on the integra grey clip there was no leftover yllw/blk wire for the signals but i did find it on the green clip and it is right next to the yllw wire that its supposed to be connected to to get the blinkers working should i remove it and tap it to the yllw wire or is it in the right location its right next to it and in the charts i found it says connect the leftover yllw/blk wire from the grey clip but mine is already on the green right next to the yllw anyways i guess ill stop rambleing on any help will be greatly appreciated
p.s i would just like to state that ive been through all the links and i found nothing about my problem dont wanna seem like im not trying but everyone else seemed to have a yllw/blk wire left over from there grey clip but i dont also if it helps its a 96 ls 5 speed dash and its going in an eg thanx again
Modified by ATX45 at 3:58 PM 4/30/2006
ok but the problem on mine is that there was no yellw/blk on the grey clip its already on the green clip and its right next to the yllw wire that it should be connected to should i tap it into the yllw one ? thanx
got some pix kinda shitty my cam is cheap
this is the grey integra clip the only yellow wires on it are ylw/silver dots and ylw/grn
this is a pic of the integra green clip with the ylw/blk right next to the solid ylw
i have the civic grey clip and im going to swap it out with the integra one but i wanna figure out my blinkers first so i can have everything correct before the install well thanx again
Modified by ATX45 at 3:52 PM 4/30/2006
cool thanx ill read through his thread again
yea well i guess im working with a obd2 harness so ill have to find a writeup for it hopefully someone who has done it will chime in thanx for the help fellas
Modified by ATX45 at 6:19 PM 4/30/2006
searched around and cant find anything about using the obd2 harness anyone know if it works the same or not i matched up my clips to the ones in litterbox's writeup and everything looks the same except for my yllw/blk wire is in the green clip right next to the solid ylw wire instead of being on the grey other than that they match up locations and all
ah ok i had it backwards but i just checked and tha blk/yllw stripe is also on the green plug should i tap it to the yllw and will i be fine or will i need the obd1 harness if you look in my picture above you can also see the black wire with the yllw stripe on the green clip
as far as i know yes that is what you would use, the black wire is always on the grey plug though the wires shouldnt be different, but i could be wrong,
check your hazard switch and make sure there is a black wire with a yellow line and if there is then i would try splicing both wires from the that green plug
redman223
Audio / Security / Video
Jul 10, 2004 07:34 AM
