JDM D15B VTEC - MINIME question
Old Apr 29, 2006 | 04:50 PM
Turboteggy's Avatar
Default JDM D15B VTEC - MINIME question
Hey guys, I'm new to the D-Series world. Had a 300 WHP LS/VTEC Integra, sold it, now wanna try to build a D-series in my EK Hatch.
Feel like such a noob asking this, but nothing found in search. Found lots on the Y8 or Z6 Minime's but nothing using the head from a JDM D15B.
My plan is to swap out my D16Y7 for a JDM D15B and build the D16 block over winter (rods & pistons - maybe sleeves.
Then come spring, pull out the D15B, build a y7block/15Bhead Mini-me and boost it.
Since the JDM D15B is VTEC and OBDI, Hondata will be a breeze.
My only question is will that block/head go together, and what will I need to do it (cam gear, belt, head gasket etc......)
Thanks very much guys.
God I hope no one posts up links from search - though I know some of you will look just to prove me worng....
Old Apr 30, 2006 | 12:10 PM
Turboteggy's Avatar
Default Re: JDM D15B VTEC - MINIME question (Turboteggy)
Anyone - my research tells me the head is the same as the D16Z6, just wanna make sure before going ahead with this.
Old Apr 30, 2006 | 02:36 PM
douspray's Avatar
z6 and d15b are the same head! the cam is different.
Old May 1, 2006 | 08:31 AM
Turboteggy's Avatar
Thanks - so this head on my Y7 block should be no problem then?
Old May 2, 2006 | 04:08 AM
912's Avatar
912
Yes convert your ek to obd1 run a p28 and your golden. Use y8 timing belt, y8 head gasket, don't forget to pull out plug on vtec oil passage, wire up vtec and boost it.
DCRB
Sep 28, 2009 08:59 AM
civicguy167
Sep 26, 2005 09:38 PM
See65
14
Mar 29, 2005 05:01 PM
Mark
Jul 2, 2003 09:41 PM
BioXide02
May 29, 2003 12:33 PM
