Quick question need answer ASAP
Old Apr 29, 2006 | 12:30 PM
DFW's Avatar
DFW
Default Quick question need answer ASAP
Friend is getting a 2000 b16a2 swap for his 99 hatch (non vtec) and want's to know if it would be a compelte just plug and play type deal. The b16a2 swap is complete with axles, mounts etc.
Can he use the stock b16 mounts since 99-00 em1 come with b16a2's from the factory and the bodies are the same?
Thanks.
Old Apr 29, 2006 | 01:26 PM
1cleangsr's Avatar
Default Re: Quick question need answer ASAP (DFW)
He will have to wire vtec but i think that's about it...as far as mounts i'm pretty sure he just uses the b16 mounts.
Old Apr 29, 2006 | 01:33 PM
DFW's Avatar
DFW
Default Re: Quick question need answer ASAP (1cleangsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1cleangsr &raquo;</TD></TR><TR><TD CLASS="quote">He will have to wire vtec but i think that's about it...as far as mounts i'm pretty sure he just uses the b16 mounts. </TD></TR></TABLE>
Cool thanks
Anyone know for sure?
Old Apr 29, 2006 | 02:32 PM
DFW's Avatar
DFW
No one has done this..?
I'm 99% sure it'll work since the front ends are identical, just need to be 100% so he can go ahead and buy mounts if necessary.
Old Apr 29, 2006 | 04:06 PM
DFW's Avatar
DFW
bump
Old Apr 29, 2006 | 06:03 PM
keemosaki's Avatar
yes mounts will work. as for vtec wiring.... yeah hes gonna have to do that. Make sure you also have the correct ECU for the motor. OBDII si ecu... forget the code on that biatch
Old Apr 29, 2006 | 06:04 PM
keemosaki's Avatar
Default Re: Quick question need answer ASAP (keemosaki)
Ohhh what do you mean by stock b16 mounts? the mounts stock on the non vtec motor? those wont work cause its for a d series. if its b series mounts, they will work.
Old Apr 29, 2006 | 08:51 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keemosaki &raquo;</TD></TR><TR><TD CLASS="quote">Ohhh what do you mean by stock b16 mounts? the mounts stock on the non vtec motor? those wont work cause its for a d series. if its b series mounts, they will work.</TD></TR></TABLE>
Yeah I'm talking about the mounts from the b16.
So he just can use b16 mounts and ecu and it'll be fine? +wiring up vtec.
Old Apr 29, 2006 | 11:09 PM
DFW's Avatar
DFW
um bump
Old Apr 29, 2006 | 11:10 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">So he just can use b16 mounts and ecu and it'll be fine? +wiring up vtec.</TD></TR></TABLE>
Yes.
Old Apr 29, 2006 | 11:37 PM
DFW's Avatar
DFW
Default Re: Quick question need answer ASAP (JDM-EJ1)
Ok cool thanks
Old Apr 30, 2006 | 09:34 AM
DFW's Avatar
DFW
bump need more than one answer
Old Apr 30, 2006 | 09:51 AM
hatchi's Avatar
plug n play just add vtec wire, knock sensor. he can retain his 2 top mounts but he needs the other 3 from the b16. He can use the 99-00 engine harness or use his stock one and add the vtec wires. Use the p2t ecu from 99-00 si also.
Old Apr 30, 2006 | 10:05 AM
DFW's Avatar
DFW
Default Re: Quick question need answer ASAP (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">plug n play just add vtec wire, knock sensor. he can retain his 2 top mounts but he needs the other 3 from the b16. He can use the 99-00 engine harness or use his stock one and add the vtec wires. Use the p2t ecu from 99-00 si also. </TD></TR></TABLE>
So it would be just easier to use all the mounts from the b16?
Thanks
ballerchild
Mar 7, 2007 12:27 AM
D3U1LT
Sep 15, 2006 09:54 PM
SwappedTURBOegg
Jan 15, 2005 01:19 AM
CRseXy
Oct 10, 2004 11:31 PM
