Need help hit curb!!
Ok i while back i hit a curb early in the morning with my eg civic. I spun out when i hit a puddle of water from the sprinklers. I ended up hitting my front drivers side wheel at a angle into the curb at about 15 mph. It now looks like this \car|. I got replaces the lca arm and it didnt do anything. So i looked at the rear crossmember and it looked like it was pushed in 1 inch bc there was a fresh paint showing by the mounting points. On the other side there was no new paint showing that was covered by the crossmember. I am just wondering if this is what i should replace or should i look into the hub that bolts to upper control arm. Any help would really help me. I already got the rear crossmember dropped just wondering if this would be the problem. Only reason im skeptical is when i lowered the rear crossmember i left the lca arms bolts up to the hub. The left side is still crooked i would think if it was bent it would go straight when its not bolted up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">put up some pics. Kind of hard to see what you are describing.</TD></TR></TABLE>
i agree
i agree
fryman
14
Jan 30, 2013 08:13 PM
krazya916
Dec 10, 2011 08:07 PM
circapunk
Apr 22, 2009 08:47 PM
