Clutch Pedal Adjustment on '00 Si
Old Apr 29, 2006 | 12:00 PM
EKDreamin's Avatar
Default Clutch Pedal Adjustment on '00 Si
Hello everyone, I recently purchased a '00 Si and have noticed that the engagement point of the clutch is abnormally high from the floor. To my knowledge, our transmissions run hyrdaulic clutch's so I was wondering if anyone knew of a way to adjust the pedal travel so that the engagement point is at a more normal, closer to the floor position. Any help would be greatly appreciated.
Scott
Old Apr 29, 2006 | 12:05 PM
SuperSlow's Avatar
Default Re: Clutch Pedal Adjustment on '00 Si (EKDreamin)
New clutch will bring it down...
Old Apr 29, 2006 | 01:19 PM
Ross 2.0's Avatar
In a Junkyard near you.
you can adjust the pedal at the slave cylinder.
Old Apr 29, 2006 | 01:49 PM
Brick Top's Avatar
theres a 12mm nut behind the connecting fork, inside the cabin, above the pedal. loosen it, its def. tight. don't strip it. turn the rod to the right slightly to shorten the engagement. tighten the nut back up.
Old Apr 29, 2006 | 03:42 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (brick top)
good ****
Old Apr 29, 2006 | 03:49 PM
EKDreamin's Avatar
Awesome, I appreciate the help.
Scott
Old Apr 29, 2006 | 04:06 PM
intevic_dx's Avatar
while that will work its wrong. you clutch is just ending its lifespan. adjusting it that way will just cause more problems.
Old Apr 30, 2006 | 02:56 PM
EKDreamin's Avatar
Default Re: (intevic_dx)
The clutch shows no signs of wear, so I don't think that's it. So is the bolt near the connecting fork the best method?
danio
Oct 25, 2012 10:40 PM
clubef9
Honda Civic (2006 - 2015)
13
Dec 11, 2008 02:20 PM
siisgood00
Feb 18, 2005 07:29 PM
Electron00Si
Sep 19, 2004 12:06 PM
MrSmith
Sep 28, 2001 08:30 PM
