tires Bald inside
Old Apr 29, 2006 | 11:17 AM
turnsignalandy's Avatar
Default tires Bald inside
Who ever said that camber dosnt mess up your tire wear? The insides of my tires are bald while the outsides have a crap load of thread left. This is after i got my allignment.
Old Apr 29, 2006 | 11:19 AM
stockfc's Avatar
Default Re: tires Bald inside (turnsignalandy)
camber does affect tire wear, caster doesn't.
Old Apr 29, 2006 | 11:31 AM
tallyturbo's Avatar
Default Re: tires Bald inside (stockfc)
^^^ i agree. get a camber kit off of ebay and call it a day
Old Apr 29, 2006 | 11:32 AM
professor poon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">Who ever said that camber dosnt mess up your tire wear?</TD></TR></TABLE>
No one.
Old Apr 29, 2006 | 11:33 AM
clint g's Avatar
Default Re: tires Bald inside (professor poon)
get the skunk2 kit pull it all the way out and call it a day
Old Apr 29, 2006 | 11:38 AM
kaiba's Avatar
Default Re: tires Bald inside (clint g)
And toe kill the tire.
Old Apr 29, 2006 | 02:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clint g &raquo;</TD></TR><TR><TD CLASS="quote">get the skunk2 kit pull it all the way out and call it a day</TD></TR></TABLE>
so if i pull the skunk 2 camber kit all the way out my camber will be at dead 0?
Old Apr 29, 2006 | 02:47 PM
95jeremie's Avatar
http://cgi.ebay.com/ebaymotors...%3AIT
this is all me on Monday dealt with the camber problems for about 2 years now (3 tiers per year on each side)
Old Apr 29, 2006 | 02:48 PM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">so if i pull the skunk 2 camber kit all the way out my camber will be at dead 0?</TD></TR></TABLE>
no but it will be alot better
Old Apr 29, 2006 | 04:12 PM
Default Re: tires Bald inside (95jeremie)
[QUOTE=95jeremie]http://cgi.ebay.com/ebaymotors...%3AIT
this is all me on Monday dealt with the camber problems for about 2 years now (3 tiers per year on each side)[/QUOT E]
ur askin 150,
I paid 150 installed
Old Apr 29, 2006 | 05:05 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">Who ever said that camber dosnt mess up your tire wear? The insides of my tires are bald while the outsides have a crap load of thread left. This is after i got my allignment.</TD></TR></TABLE>
Post your alignment printout.
Old Apr 29, 2006 | 05:33 PM
Default Re: tires Bald inside (Targa250R)
the guy at midas alligned the front to factory specs. Im pissed cause i spen 200 some bucks just so that i dont run in this problem. Could i go back to midas and make a big deal bout it. I specifically said 0 camber on the front.
Old Apr 29, 2006 | 06:35 PM
.Ry's Avatar
.Ry
how do you know the TOE isnt back out?
Old Apr 29, 2006 | 06:46 PM
FalkenSiR's Avatar
Let's see the specs, Dr. suspension.
What did you tell them to do?
Did you just hand the keys?
How long after the alignment?
How bad was it before and after?
Old Apr 29, 2006 | 07:33 PM
Default Re: tires Bald inside (fast88std)
i told them 0 degree camber on the front. Its been about 2 months or so since i got it lowered. I got tein springs with skunk 2 camber kit up front. Took it to get alligned, told them 0 toe and 0 camber. I picked up the car, i asked them if they did what i asked and they said ya its factory specs. I looked at my front tires and the tirers are bald on the inside. For my rear tires i used some bigger bolts and it fixed the camber within .4 degrees of 0. The tires are worn pretty damn even. U think the guys at midas didnt tighten the camber kit enough and it un adjusted over time?
Old Apr 29, 2006 | 07:37 PM
JDM-EJ1's Avatar
Default Re: tires Bald inside (tallyturbo)
You can noticeably tell if your camber is off. Just get behind your car and look at your tires. They should be like this: | |. Your's may be like this / \. Get an Ingalls, Skunk2, etc camber kit and be done with it.
Old Apr 29, 2006 | 08:53 PM
instrument's Avatar
people really dont read posts ehhh
that sucks that they're worn..but how did you not notice until they were all the way bald? Your car must be a little lowered so you definitely need to keep an eye on your tires...just turn the wheel every now and then...it'll take 10 seconds.
but seriously, most shops will show you a print out of your camber/toe when you brought it in, and where they got it...
when i was much younger i had a shop install my kit on my crx....they did a horrible job and the upper arm got stuck in the fender sheet metal...i had to pop it out and bang on it...
so yeah..don't just trust anything a shop tells you.
Old Apr 29, 2006 | 09:35 PM
YeeJ6's Avatar
Default Re: (instrument)
check your toe angle, bad toe will wear tires down faster than exesive camber. post a pic of your car so we can see how bad your camber is
Modified by spoonspeed at 7:53 AM 4/30/2006
Old Apr 29, 2006 | 09:37 PM
YeeJ6's Avatar
Modified by spoonspeed at 7:52 AM 4/30/2006
Old Apr 29, 2006 | 10:58 PM
Default Re: (spoonspeed)
I just noticed it when i took off my resonator, two days ago. But ya my right upper controll arm looked like it was scrapin against sometin. I dont know how to post pics here
JDM_FRONTIN
Sep 15, 2007 10:09 AM
98savage
May 15, 2007 01:13 PM
Personal Submarine
Jan 7, 2005 10:56 AM
tolowhb
23
Nov 24, 2004 09:57 AM
CivicSwapper
Dec 11, 2003 06:53 AM
