intercooler couplers Home Depot?
Im short a couple of couplers. Will the plumbing rubber Hoime depot ones work or will they melt? Id place them after the intercooler which should be a bit cooler. Anybody do this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denske »</TD></TR><TR><TD CLASS="quote">don't use them, they rip down the middle from the pressure.</TD></TR></TABLE>
the heat also kills them
to answer your question, yes they will work. the napa hose is better, but the fernco couplers will do the trick! i think i have four on my car right now, holding 8 psi just fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkeith »</TD></TR><TR><TD CLASS="quote">NAPA radiator hose in the size you need. Works like a charm.
And I use a 90 deg bend radiator hose for some of piping to my intercooler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scartail »</TD></TR><TR><TD CLASS="quote">
And I use a 90 deg bend radiator hose for some of piping to my intercooler.</TD></TR></TABLE>
Same here!
And I use a 90 deg bend radiator hose for some of piping to my intercooler.</TD></TR></TABLE>Same here!
i have used the home depot couplers also, for the charge pipes and on the turbo itself for the intake, so far so good. i do feel however if i did it again i'd probably get 1 or 2 feet of the 4 ply silicon stuff, i think you can still find it this way for somewhat cheaper than paying $24 a piece.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">24 dollars a piece?!?! they are like 1/4 that cost, you can get a set of 4-ply couplers and t-bolt clamps for like 40 bucks...</TD></TR></TABLE>
Ebay baby!!!
Ebay baby!!!
the rubber only plumbing couplers from lowes/home depot suck *****. What ever you do don't use them; you'll regret it.
Get some nylon reinforced hose from napa or a reinforced radiator hose with the correct bend(s) in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pay2play killa »</TD></TR><TR><TD CLASS="quote">the rubber only plumbing couplers from lowes/home depot suck *****. What ever you do don't use them; you'll regret it.
Get some nylon reinforced hose from napa or a reinforced radiator hose with the correct bend(s) in it.</TD></TR></TABLE>
i use them and dont regret it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">i use them and dont regret it</TD></TR></TABLE>
you're lucky. of the 3 cars i've seen them on they've all had problems
