HELP!! temp. guage gets to 3/4 before fan comes on!!!!
Old Apr 28, 2006 | 09:50 PM
rextec's Avatar
Default HELP!! temp. guage gets to 3/4 before fan comes on!!!!
my car gets hot at idle only! when i am cruising it is perfectly fine. i jumped my fan while it was idling and the temp stayed at half but when i let the fan run off of the stock temp. switch it gets to 3/4 then comes on! it has a new temp. switch, thermostat, fluidyne radiator, no leaks, headgasket is fine, fan relay works, fan works, fan blows air the right way, new 16lb. radiator cap, and it has been burped and bled many times. i switched everything out and it still happens. its really pissing me off.
p.s. i searched and found similar topics but no cures for the problem were posted.
Modified by rextec at 10:42 PM 4/29/2006
Old Apr 28, 2006 | 09:54 PM
schardbody's Avatar
you sure you replace the correct CTS, one is for the fan the other is for the gauge. unplug the one you replaced and see if the gauge works, if not, you replaced the wrong one. if thats not the problem i dont have a clue.
Old Apr 28, 2006 | 09:58 PM
rextec's Avatar
yes, i replace the one on the thermostat housing not the one on the head.
Old Apr 28, 2006 | 10:00 PM
schardbody's Avatar
wow, thats weird then, bump for you.
Old Apr 29, 2006 | 10:27 AM
rextec's Avatar
bump
Old Apr 29, 2006 | 12:13 PM
slowturbocx's Avatar
Default Re: HELP!! temp. guage gets to 3/4 before fan comes on!!!! (rextec)
i have same problem . bump bump bump
Old Apr 29, 2006 | 03:19 PM
rextec's Avatar
ttt
Old Apr 30, 2006 | 09:17 AM
rextec's Avatar
ttt
Old Apr 30, 2006 | 09:28 AM
crazyracer817's Avatar
i have the same problem also...i changed my cool fan switch...and now it works fine...
Old Apr 30, 2006 | 10:05 AM
rextec's Avatar
Default Re: HELP!! temp. guage gets to 3/4 before fan comes on!!!! (crazyracer817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyracer817 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem also...i changed my cool fan switch...and now it works fine...</TD></TR></TABLE>
thats what i thought it was but i changed it and it still does the same thing.
Old May 1, 2006 | 11:34 AM
rextec's Avatar
bump
Old May 1, 2006 | 03:10 PM
rextec's Avatar
someone has to know
Old May 2, 2006 | 09:08 AM
rextec's Avatar
up
Old May 2, 2006 | 02:03 PM
rextec's Avatar
ttt
Old May 4, 2006 | 08:54 AM
rextec's Avatar
help!!
Old May 4, 2006 | 01:36 PM
rextec's Avatar
:sigh:
Old May 5, 2006 | 09:15 AM
rextec's Avatar
up again
Old May 8, 2006 | 09:05 AM
rextec's Avatar
bump
Old May 12, 2006 | 10:27 PM
rextec's Avatar
still need help
Old May 17, 2006 | 10:08 AM
rextec's Avatar
ttt
Old May 17, 2006 | 04:59 PM
berso's Avatar
here's what the service manual says:
Engine Coolant Temperature
Problem verification:
1. Start the engine. Hotd the
engine at 3,000 rpm with no
load (in Park or neutral) until
the radiator fan comes on,
then let it idle.
2. With the scan tool, check the ETC
is 176-200'F {80 - 93'C)or
0.4-0.7 V indicated?
Yes?
Intermiftent failure. system is OK
at this time. Check the thcrmostat
and thc cooling system.
No?
Check the thermostat and the
cooling system. ll they als OK,
replace the ECT sensor.
Not because you already change a part, is 100% sure that it'll work it may be defective, if i where in your shoes, i'll start by plugin some external temp gauge to find out more exactly at what temp the fan is starting, if is actually wrong, then i'll find out if the ETC sensor have the rigth Voltage and go from there...
Old May 17, 2006 | 05:43 PM
rextec's Avatar
Default Re: HELP!! temp. guage gets to 3/4 before fan comes on!!!! (berso)
thanks for the help
aasaa666
May 31, 2010 07:15 AM
Shade93
Apr 13, 2010 01:15 PM
oneEg1Tc
Jul 22, 2009 09:15 PM
turbotime
Nov 14, 2005 12:45 PM
JDM R
Jan 15, 2005 11:50 AM
