Someone that KNOWS help me
Old Apr 28, 2006 | 07:04 PM
bukfuddie's Avatar
Default Someone that KNOWS help me
Hey i have a 93 prelude vtec h22.......my vtec doesnt work......the only check engine light that i have is a 8 the tdc sensor...from reading on here i learned that this sensor is in the distributor. I took off my cap and rotor and inspected everything, it is clean in there and all the wires that i could see from taking off the cap and rotor are attached and in good condition. I also learned that the sensor reads off the camshaft.....i dont want to take out the dizz and spend 200 buks and install a new one wit hthe same results.
What else can I do or Check? What is casuing this sensor to come on?
Who sells just tdc sensors? If not can i salvage one out of a non vtec prelude???
the car takes a acouple seconds of turning over before it starts but besides that it runs awesome......just no vtec.
Please someone help me so i can start driving this again!
Old Apr 28, 2006 | 07:16 PM
92hondalude's Avatar
Default Re: Someone that KNOWS help me (bukfuddie)
the cars that take the reading from the crank are the 96 and up (OBD2 Prelude)
about just getting the sensor im not sure but i would think you caould just buy the sensor. and yes you can get it off a non vtec h23
Old Apr 28, 2006 | 08:37 PM
bukfuddie's Avatar
Default Re: Someone that KNOWS help me (92hondalude)
yea autozone LMAO told me there is no such thing in their computer of a tdc sensor......napa told me to buy a whole new distributor....this sucks
NOW how do i tell which sensor is the tdc in the distributor? will the tdc off a sohc f22 work?
Old Apr 30, 2006 | 01:06 PM
bukfuddie's Avatar
Come on people i need your opinions...share some knowledge
Old Apr 30, 2006 | 01:56 PM
helicopter201's Avatar
wow posted the same question twice...
https://honda-tech.com/zerothread/1596208
Old Apr 30, 2006 | 04:57 PM
lude of pre 2.3's Avatar
alright manyour pry talkin about the ignitor chip which is a control module that controlls spark dwell other than that i am not sure that there is a tdc sensor in the distributor if ur not hitting vtec check ur vtec soleinod positioned near the dist. on the intake cam vtec is controlled by oil pressure i believe so mabey your pcm isnt getting a reading for oil psi mabey put an oil psi sensor in and see what it does they are like 5 bucks
Old May 3, 2006 | 08:10 PM
bukfuddie's Avatar
today i took a dizzy offa a f22a1, tore it apart and took out the tdc sensor. At first i was leary if the sensor would be the same seeing its a sohc motor and mine is a dohc. The distributor housing on the f22a1 and h22a1 are different but actually have the same internals. I then continued to take the h22a1 distributor apart. I replaced the bushing and seal that the shaft runs through, as well as the tdc sensor. All i had to modify was the wires from the tdc sensor. I had to make them about 2 inches longer. Put it all back to together. BINGOOO VTEC BABY........screw spending $200 on a dizzy like some of you had told me. I recommend anyone doing this if they have the same problem I had. It is lots cheaper and is not hard at all to do. WIll also work for the Crank angle sensor, Crank Positions sensor, and the icm.
Seroga415
Jun 16, 2012 07:57 PM
JsSIR
Jul 14, 2008 08:14 PM
bukfuddie
Apr 16, 2006 12:49 PM
dcrbin22
May 20, 2004 05:50 AM
hybrid22l
Feb 24, 2002 08:17 PM
