What's the worst case scenerio of not having a resistor box?
I have a OBD1 h22a swapped into my eh2. I purchased the car with the engine already swapped and today a friend noticed that there isn't a resistor box at all. The car has been running like this for at least 3 years.
What can happen if one isn't installed? Since I've been running it like this for so long can I see problems by installing one now?
I've searched all through the archives and found lots of info but none told what's the outcome of not running a resistor box.
the use of resistor box depends on what injectors your using, and what ecu. if its been ran for 3 years then most likely this guy knew that and set it up accordingly. but for ***** and giggles find out what ecu and injectors you have, and we'll go from there.
yeah i too say its prolly already setup to run without. i doubt it would work otherwise.
if youre lookin for a box, i saw a few on ebay today pretty cheap.
it's an obd1 P13 ecu. How do I find out what injectors I have?
Upon inspecting the car after I purchased I replaced misc. missing bolts, re-installed the throttle cable and tons of other things that wern't right. I really wouldn't doubt that they completely forgot to put a resistor box when one was needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">i thought that video said more like 30 seconds....ehh i havent watched it in a long time...
either way, obviously yours are fine...</TD></TR></TABLE>
Sorry to surprise you but they are peak and hold injectors. I am lucky that no damage occurred for 3 years. Needless to say, I now have a resistor box installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">are u sure they are peakholds? because it is alomst physically impossible for an ecu to withsatnd that kind of heat for 3yrs.
what was the resistance across the injectors?</TD></TR></TABLE>
The injectors have a resistance of exactly 3-3.1 ohms. They are low resistance injectors which lasted 3 years without a resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 »</TD></TR><TR><TD CLASS="quote">sounds to me like you have saturated injectors, especially if the engine is not boosted and doesn't need especially large injectors</TD></TR></TABLE>
93-96 h22a motors come with 345cc low resistance peak & hold injectors.
blackntegra
Oct 29, 2006 11:49 PM
