00 B16B into 99ex wiring help please...
Have a question about my swap...most of my research was for a B18c5 and i switched to a b16b. I know for the b18c5 i needed to change axels and likage and what not to 99-00 Si parts. Do i need to do that with the b16b axels or will they work? Now on to wiring someone told me that a engine harness from a 99-00 Si would be totally plug n play for this swap is this true? I've searched was unable to find anything on this swap.
Thanks
Thanks
all the sensors should be plug and play but you need to wire the vtec in. you also need a vtec ecu. if it was me i would buy a obd2 to obd1 jumper harness and use a p28 chiped but thats me. the passenger side axle use a 99-00 si and the drivers side axle depends on the type of intermidate shaft you use
92EG8
11
Nov 17, 2006 08:50 PM
thalwr1
Jun 15, 2006 12:10 AM
