Clutch Problem
so the other day i finished up my engine swap and now my clutch feels funny. i bleed it dorve the car aroun d to make sure it was running good parked it. thenthe next day the clutch pedal felt really soft and sloppy and it should be stiff(stiffer then stock) ((act stage 1 clutch)) every thing work fine in my other car so im thinkin it the master cylinder what do u guys think
follow your clutch pedal up to the fire wall to see if you see fluid, if you do then your MC is bad. next go to your slave cylinder and pull the black boot back to see if theres fluid in there, if there is the SC is bad.
Hard2Find
Mar 12, 2002 03:17 PM
