How long should my runners be for a custom intake mani???
Old Apr 28, 2006 | 09:38 AM
B18 CYA's Avatar
Default How long should my runners be for a custom intake mani???
im getting a customer intake mani made from my buddy, were cutting a gsr manitolf off at the flange and putting round runners up to a box of some sort with v-stacks at the ends of the runners inside it.
how do you know how long to make the runners as to where power will be made?
on top of that ill be running a 70mm TB with a prototype racing v-stack.
where do you want the power to be? i know the todas give good midrange, but im selling them for PRO2's most likely cause i dont see good results on the them
85mm gsr block
89mm stroke
1" DECKPLATE
custom 6.3337" cunningham ultra lites
custom 13.5:1 arias pistons 7cc dome
RMF narrow 2.5"
head is fully ported and polished
toda c's (selling for some PRO2's though)
Old Apr 28, 2006 | 01:56 PM
93-lsvtec-eh2's Avatar
Default Re: How long should my runners be for a custom intake mani??? (B18 CYA)
it really all depends where you want to make your peak power. Donf should chime in shortly and he can go into detail about the lengh and runner size and approach angle to the valves.
Old Apr 28, 2006 | 02:11 PM
B18 CYA's Avatar
where are you donf
Old Apr 28, 2006 | 02:19 PM
rainforest's Avatar
Default Re: (B18 CYA)
hey iam not donf but i'll give you a smart *** comment with my answer if you want.
http://snow.prohosting.com/~jo....html absolutlly everything you need its a intake manifold runner length and diameter calculator.
Old Apr 28, 2006 | 02:59 PM
DonF's Avatar
Default Re: (rainforest)
It's "beer thirty" in Fl on a friday. 13.5 -14 inches, valve to end of runner. Peak at 8700-9000. Back to scheduled binge. You will also need ports and cams to support that.
Old Apr 28, 2006 | 03:26 PM
rainforest's Avatar
Default Re: (DonF)
awsome that damn close on the calculator.
Old Apr 28, 2006 | 03:33 PM
DonF's Avatar
I will read the calculator thing tomorrow.
negusjuda
Dec 17, 2010 10:51 AM
tylergrae
Jan 31, 2010 09:49 AM
1Bluegsr
Feb 8, 2007 12:11 PM
integracivic94
Sep 5, 2006 07:47 AM
white_jdm21
Feb 5, 2005 03:03 AM
