Help with a future build
Okay guys- im not in any sort of trouble or nothin, but i need some help for future preparation of an all motor set up
Car: 1995 EJ1
MOTOR: 1998 USDM ITR - stock.
Tranny:S80
Question: What exactly can be done. I mean i know about all the bolt on stuff basically, Cams, cam gears- yadda yadda yadda... but what i need to know is all the technical stuff. Considering im completely stupid when it comes to machining and head work, i need some kind of break down on what kind of head work there is as in Milling the head, decking the block. I mean sure i can sit here and say thing, but i have no clue what im talking about. I need someone or a couple of people to help me out here by explaining it too me. I try'd to do a search but nothin came up on a mild set-up on an itr.
I just want a Mild set-up, so that when the time comes i can drop this motor back into my daily driver, but still be able to run low 13's - mid- high 12's. Expense isn't really an issue right now, i just need somewhat of a plan to be laid out, to things that will give me the most beneifit, without blowing my compression ratio out the water. Like i said a mild setup no 13+ Cr setups, maybe a 11.5-12:1 on a daily driver. I have a year to do all this stuff, cuz im dropping the motor out of my car now, and puttin a b16 in as a Daily driver and the ITR is going on an engine stand
too be built over time. Thanks for anyone that helps!
**Edit* forgot to say that when i say mild i mean within the 195-210 whp range, nothing extremely raw
Modified by Ej1-R at 11:13 AM 4/28/2006
Car: 1995 EJ1
Tranny:S80
See thats where i run into a wall at.. I dont know the names for everything that can be done.. Thats my only bad spot at the moment.. I need to know the names of some of the things machine work wise... I know this isnt easy, but im just learning about everything on my own,so its a bit harder.but thanks
**Edit** found a website that tells me everything i need to know about things that can be done machining wise.!... now comes for the question about the set-up. A Mild street build is all im wanting. Something thats not gonna break down every week. most importantly i dont want a SUPER high Compression Ratio...13+ is too much, anything under that with a tune will be good. Im the first to admit im retarded, but o well u gotta learn somewhere
Modified by Ej1-R at 11:09 AM 4/28/2006
https://honda-tech.com/zerothread?id=1461564
https://honda-tech.com/zerothread?id=1446279
https://honda-tech.com/zerothread?id=915257
https://honda-tech.com/zerothread?id=1375500
https://honda-tech.com/zerothread?id=731671
these are just some I found a lot but just read up ull catch on and hopefully this get u started
I think you can do it stock block....(thinner headgasket for a lil bump in compression) just need an smsp header w/ some krazy *** tune and some cams w/ valvetrain
mattcivic
11
Sep 23, 2004 01:20 AM
