Car Idles Rpm Up and Down
Old Apr 28, 2006 | 05:41 AM
standbackimapro's Avatar
Default Car Idles Rpm Up and Down
Usually when i start my car in the morning or after it hasnt been drivin in a while
My idle usually goes up and down id say it goes up to about 2k then down to like 800 then up and down for about 10 minutes
I replaced the air intake temperature sensor
Old Apr 28, 2006 | 07:14 AM
Ped_Xing's Avatar
Default Re: Car Idles Rpm Up and Down (standbackimapro)
When my 94 lx did this the shop told me it was the throttle position sensor.
You might want to let everyone know what kind of accord you're having trouble with.
Old Apr 28, 2006 | 07:27 AM
Ross 2.0's Avatar
In a Junkyard near you.
90% of the time when this happens the Idle Air Control valve has taken a dump on you. Try taking if off and give it a good cleaning with throttle body cleaner.
It's amusing to see someone with a SN like yours asking a question
Old Apr 28, 2006 | 08:32 AM
accordcg3's Avatar
Yea thats def. the IAC very common with early and mid 90's hondas. Take it off and give it a nice cleaning like moogocow3 said and if it still does it cough up the loot to get a new one. There fairly cheap.
Old Apr 28, 2006 | 12:20 PM
lowered94accord's Avatar
Default Re: Car Idles Rpm Up and Down (accordcg3)
clean it and if that doesnt help then you probably have a leak and you can either buy a new one or you can find the leak and put a patch on it like i did
Old Apr 28, 2006 | 01:25 PM
accord-pro's Avatar
why don't you start with year and model..
it will make helping you a lot simpler
Old Apr 28, 2006 | 04:43 PM
gianinline's Avatar
Default Re: Car Idles Rpm Up and Down (Ped_Xing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ped_Xing &raquo;</TD></TR><TR><TD CLASS="quote">
You might want to let everyone know what kind of accord you're having trouble with.</TD></TR></TABLE>
Maybe that's because he has a nissan photo in his avatar......
Old Apr 29, 2006 | 05:22 PM
Sorry its a 1990 accord dx
Old Apr 29, 2006 | 05:36 PM
accord-pro's Avatar
Default Re: (standbackimapro)
make sure there are no vacc leaks, chk the idle adjuster screw make sure it has not backed almost all the way out, remove the top cover of the fast idle valve and screw in the inner valve,,
try these and post results..
Old Apr 29, 2006 | 06:23 PM
hondadude's Avatar
Check the coolant level first, be sure the block is burped thru the 12mm bleed screw at the T-stat housing
legacy1644
Oct 18, 2008 12:05 AM
buh
Oct 5, 2004 09:19 PM
vandeec5
Mar 11, 2004 09:05 AM
plnoldrick
11
Jun 6, 2002 01:10 PM
