Question with timing belt cover.
Will basically I smog my car last year (with D15B2) and the DMV wants me to smog it again this year (currently have D15B VTEC now). My question is
1. Are all the D series timing belt cover the same? I don’t have the stock one because I ripped the stock JDM one apart.
2. Is there another way to check my timing other than the timing light?
3. And for last, is it easy to exchange the timing cover by taking off the crank pulley.
I really appreciate with any information.
there is a difference between the non vtec timing belt covers and the vtec timing belt covers.. and let me warn you.. if u get pulled over the cop can give u a ticket if you dont have your cam gear cover on..
my friend got one he said it was because racers dont put it on so they can adjust their cam gear.. but my friend didnt have an adjustible.. stupid cops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">there is a difference between the non vtec timing belt covers and the vtec timing belt covers.. and let me warn you.. if u get pulled over the cop can give u a ticket if you dont have your cam gear cover on..
my friend got one he said it was because racers dont put it on so they can adjust their cam gear.. but my friend didnt have an adjustible.. stupid cops</TD></TR></TABLE>
Damn, so do you think a Z6 timing cover work on my D15B Vtec?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 »</TD></TR><TR><TD CLASS="quote">Damn, so do you think a Z6 timing cover work on my D15B Vtec?</TD></TR></TABLE>
yes im pretty shure it will fit properly
I would think the VX would work, but i'm not sure.
NO, they are not.
D16Z6 is actually smaller than all the others. - and upper and lower covers between the d15's and the d16 are not compatible with each other.... i.e. an upper cover from the D16 will not work with the lower cover from a d15.
If you need one in a hurry (besides the stealership) goto http://www.car-part.com and see if a local junkyard has one. - I bought one in great shape a couple of weeks ago for $20.00 (upper and lower and all gaskets).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">D16Z6 is actually smaller than all the others. - and upper and lower covers between the d15's and the d16 are not compatible with each other.... i.e. an upper cover from the D16 will not work with the lower cover from a d15.</TD></TR></TABLE>
D15B7 is different from JDM D15B. The D15B is more like a VX, or d15z1.
FOMULA91
Apr 28, 2006 03:29 PM
