Quick Headlight Question
Trying to adjust the headlights on my 95 civic ex, all seems to be working pretty well except the adjustment on the left one, not seeing the beam move anywhere.
1. What's the best way to adjust your headlights? Against your garage door?
2. When you buy a new pair of headlights, does it come with the whole assembly, the adjusters on it and everything?
Overall I have to drive around with my high beams on just so it looks like I have normal headlight settings so I can see the road. When the high beams are off....I only see one light shining on the ground coming from the right headlight and barely anything showing from the left headlight...tried adjusting it but nothing shows. Any similar experiences from anyone? When you guy new headlights are they already pretty much aimed?
may be its adjusted all the way now. What you can try is to take it off move it around (may be it wasnt installed correctly) bolt it back down. and if it still doesn't work try putting washers so the head light can sit higher
There are four bolts you use to adjust the headlights. Two on the top, one towards the middle of the car, and one on the side of the headlight behind the corner light. You loosen those, position the headlight to how you want it, then re-tighten.
INVALID
10
Sep 22, 2002 02:42 AM
