B18A block and ITR clutch disc?
Old Apr 8, 2002 | 09:00 PM
Project_Integra's Avatar
New User
Default B18A block and ITR clutch disc?
Did a search and can't find a good answer, does a b18a block with ls cable tranny accept an itr clutch disc? Let me know, thanks.
Old Apr 8, 2002 | 09:04 PM
Urban Business
Guest
Posts: n/a
Default Re: B18A block and ITR clutch disc? (Project_Integra)
call up honda and ask them how many splines are on the clutch disc also how large it is. it'll probably work. just needs to fit the pressure plate. and seat it self correctly on the spindles
Old Apr 12, 2002 | 03:18 AM
Rocket's Avatar
Depends on your tranny. If your tranny is a 90-91 then the input shaft is too small. If you have a 92-93 tranny you are okay.
Here are the specs
90-91 tranny: Shaft diameter 31/32"; Splines 24.
92-93 tranny: Shaft diameter 1 and 1/32"; Splines 24.
This means that the ITR disc will fit on the 90-91 but the hub on your disc will be stripparooney in no time.
turbo-crx
Transmission & Drivetrain
Dec 5, 2008 11:56 AM
mike9571
Apr 15, 2007 10:02 AM
marc-111
Jul 27, 2006 10:58 PM
baked_beanz
Sep 14, 2005 10:48 AM
AllmotorJunkie
Jun 13, 2003 02:52 PM
