my setup
what do you guy think my motor will produce with this setup?
JE 12.5:1 pistons
Eagle rods
SMSP header
S2 pro 2 cams
ported head
oem valves
s2 retainers, springs
venom intake manifold
Crane cam sprockets
AEM fuel rail and regulator
Hondata s300 tuned
If you think that i should add something else, I am open for opinions. Thanks guys
JE 12.5:1 pistons
Eagle rods
SMSP header
S2 pro 2 cams
ported head
oem valves
Crane cam sprockets
Hondata s300 tuned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRuckas »</TD></TR><TR><TD CLASS="quote">Not so much power as it gives great torque gains.</TD></TR></TABLE>
Horsepower = (Torque x RPM) / 5252
why stop there? do a couple more little things and tune the **** out of it.
might as well go oversized on the pistons with a fresh bore/hone.
also, throw in a 1 or 2 layer headgasket and maybe some flat valves for a bit more compression (assuming there is enough clearance of course), and a fresh valve job/seals while your in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">ditch the stock fuel pump and put in a walbro 255lph so you won't lean out
A stock pump would be fine for what he's planning on running. I'm running a stock fuel pump with RC 370's on a bigger setup than that with no problems at all. Can't beat OEM reliability.
</TD></TR></TABLE>A stock pump would be fine for what he's planning on running. I'm running a stock fuel pump with RC 370's on a bigger setup than that with no problems at all. Can't beat OEM reliability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote">A stock pump would be fine for what he's planning on running. I'm running a stock fuel pump with RC 370's on a bigger setup than that with no problems at all. Can't beat OEM reliability.</TD></TR></TABLE>
Stock fuel pump wow really..... I never thought they would be enough for 2.0L motors.
I am running a walbro but I am on RC440CC injectors. Plus the high whine of the fuel pump is intimidating when you sit in your car and place the key in the ON position
Chefskinny
Apr 1, 2016 01:07 AM
Nicks95GSR
Jul 13, 2008 01:21 PM
b18pwr
12
May 6, 2005 03:14 PM
