where to buy longer head studs
i'm looking for the longer studs that hold the intake manifold to the head since the hondata gasket is thicker than the paper gasket...
Buy a piece of threaded rod from the hardware store and cut your own, if you have access to a dremel. That would be super cheap also. How thick is that gasket anyway?
"The stock studs are 25mm long. You can use these studs, which are 35mm long. They retail for less than a buck each, and you can order them from any Honda or Acura dealer."
mike K
92900-08035-1B
Bolt, stud (8X35) https://honda-tech.com/zerothread?id=132940
mike K
92900-08035-1B
arielb1
11
Nov 5, 2004 02:38 PM
