Threded plugs in crankshaft
I have heard of people doing this and I wanted to know how to do it exactly, if its actually safer, and how many holes there are to plug. I think it is also refered to as 'whelch' plugs or somthing like that? does anyone know exactly how many are in/on a d16y8 crank? where can I buy the threded plugs to use? thanks
Edit: found a little more info on another web site.. but still need to know how many holes there are in the d16y8 crank so I can tell the shop thats doing the machining on my engine how many there are
Taken from the web site:
Here is an example of a
stock pressed in oil galley
plug. These should be
drilled out and replaced
with loctighted screw in
plugs.
This crank has had its
stock oil passage plugs
with screw-in plugs. These
plugs are more secure and
allow removal for cleaning.
Modified by dohdoh420 at 11:08 AM 4/27/2006
plugs.
Jimi Hondrix
Jul 19, 2015 05:22 PM
