Strange Idle after hondata s200/street tuned...
The engine is a completely stock b18c-r. The only mods are a hytech header, catback, and j's intake.
So to manage the air/fuel, I decided to go s200 to just get the installation out the way for later uses.
I'm running a p28 chipped for hondata and a s200.
Had the motor street tuned with wideband for now.
Dyno before (dynopac):
http://deviantpixels.com/zdrive/dyno1.jpg
Dyno after (dynojet):
(I was told this was good because the dynos are different so it's really better than the before dyno which has a higher hp gain)
http://deviantpixels.com/zdrive/dyno3.jpg
Anyway, everything feels great. Definately feels smoother. The problem is when I come to a complete stop the idle surges between 1200 and 1500 rpm's. Then after doing this for a few seconds, it drops to about 1100 or 1200rpm's and holds a steady idle there.
Is there something wrong? I still have my jdm itr ecu and it idles perfectly fine with it installed (around 800rpm's) so it's something with the hondata I'm guessing.
Anybody know?
Anybody know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">Idle air control valve duty cycle, try adjusting that.</TD></TR></TABLE>
Adjusting it inside the hondata program?
Hopefully that wasn't a dumb question
And if it's not in the hondata program, why would it run perfectly with the oem ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">Yes, it is an option in the software.</TD></TR></TABLE>
Cool, I'll ask the tuner. Thanks a lot for the help.
I suffer from the same problem, I wonder why my tuner didn't adjust it when the car was dyno tuned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nholmes »</TD></TR><TR><TD CLASS="quote">I suffer from the same problem, I wonder why my tuner didn't adjust it when the car was dyno tuned.
Not sure, maybe it just didn't stand out. I don't think my car did it while it was getting tuned, then suddenly the day after I noticed it
It's like suddenly feeling sick after you just got back from the doctors.
</TD></TR></TABLE>Not sure, maybe it just didn't stand out. I don't think my car did it while it was getting tuned, then suddenly the day after I noticed it
X2
and I think to myself... "all luxury cars behave in this fashion."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay_animation »</TD></TR><TR><TD CLASS="quote">The problem is when I come to a complete stop the idle surges between 1200 and 1500 rpm's. Then after doing this for a few seconds, it drops to about 1100 or 1200rpm's and holds a steady idle there.</TD></TR></TABLE>
Mine doesn't do it every time... seems like only after I beat on it. Perhaps it's the engine getting back at me. It's saying... "F your momma... here's a bad idle for you". I've also noticed that when using the a/c the idle wants to drop a bit and the varied idle sitution increases. BTW... S200B I'm using with a JRSC.
</TD></TR></TABLE>X2
B18C2_sedan
Aug 19, 2006 07:11 AM
Stock@$$GSR
Apr 18, 2002 05:10 PM
