97 civic automatic tranmission code 16
Old Apr 27, 2006 | 06:51 AM
Racersky's Avatar
Default 97 civic automatic tranmission code 16
does anyone know what does code 16 mean? when i check for the code it show one long flash and six tiny flash, i assume it mean 16. or does anyone have a link to all the code????
Old Apr 27, 2006 | 06:54 AM
djsire's Avatar
Default Re: 97 civic automatic tranmission code 16 (Racersky)
u have got to be really lazy it tells you the ecu codes right abouve your post
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Old Apr 28, 2006 | 07:28 AM
Racersky's Avatar
I asked for Transmission code, it be nice if you read...... but thanks for the engine code anyway
Old Apr 29, 2006 | 02:31 PM
djsire's Avatar
Default Re: (Racersky)
well if you look up
https://honda-tech.com/zerothread/1171263
all the codes you ever need
also what the hell are you talking about? transmision codes? if u suedthe paper clip method than the codes abover are what you need. if you used the data logger the rest of the codes will be in that post.
98tegLSvtec
Jul 31, 2011 01:33 PM
93b20z
May 18, 2009 04:59 PM
CustomX113
11
Sep 1, 2006 01:27 PM
Phrost
May 29, 2006 02:44 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
