Suspension & Brakes Theory, alignment, spring rates....
stripped alan bolt for gc coilovers?
Old Apr 26, 2006 | 10:03 PM
harlen's Avatar
Default stripped alan bolt for gc coilovers?
i bought a used set of gc coilovers and found that one of the alan bolts on the spindle to the sleave was stripped. whats the best way to get this dam bolt out?? TIA
Old Apr 26, 2006 | 11:00 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: stripped alan bolt for gc coilovers? (harlen)
Mine are stuck, but not stripped. For yours, I would see if you can cut the bolt in between the split in the collar. This will take the load off and you can use a screw extractor.
Old Apr 26, 2006 | 11:30 PM
EK4civichatch's Avatar
When it happened to me I just took a torx bit one size bigger, tapped it in with a hammer, and used a socket to get it out....
Old Apr 26, 2006 | 11:53 PM
harlen's Avatar
Default Re: (EK4civichatch)
the bolt looks corroded on there. would the screw extractor be best way? cuz thats what i was thinking about doing.
Acura Del Sol
Suspension & Brakes
12
Feb 22, 2012 10:56 AM
LukieLuc
Mar 20, 2008 01:08 PM
Beau Gotti
Suspension & Brakes
Oct 19, 2005 04:24 PM
jbell
Jul 7, 2005 09:06 AM
Mikey
Apr 25, 2003 08:47 PM
