'Ram Air'
And no...I don't mean short ram intakes.....
I was wondering if anyone has tried ducting air from the high pressure area in the front of the air dam....like where the fogs go. If you could make the pipe straight enough it would seem that you could increase the pressure of the intake charge. Granted this will most likely require a battery relocation, but I was going to do that anyway. At the very least the air is as cold as a CAI.
There has been a ton of discussion on the effect of 'Ram Air'. I think it boiled down to the fact that to notice any performace gains from Ram Air, you would need to be going about 250 mph.
Somebody correct me if I'm wrong.
Hey LudeLC,
check out this link I was on HP.com and somebody had the same question. They wanted to know if XXX MPH through the intake could be translated into PSI.
Its slightly different from your questions, but maybe you'll get some answers.
http://www.hondaprelude.com/webboard...d_id=0&style=2
EDIT: And by adding a "ram-air" effect to your intake you arent increasing pressure, you are increasing the air velocity and airflow. The only way to increase pressure is by compressing it (Turbo or Super).
I think the only way to increase pressure via "ram-air" is to go very fast...I'm talking about breaking-the-sound-barrier kind of fast. Thats just speculation though.
[Modified by BlueShadow, 10:31 AM 4/10/2002]
I doubt in our Preludes we could find a way to actually increase air pressure "measurably" with a system like this. But I am thinking about trying to fabricate my own system similar to the Comptech Icebox for my 4th gen VTEC.
What I want to do is get rid of my AEM CAI. Purchase a short-ram intake. Then fabricate a sealed box to shield engine bay heat. I would have an opening at the bottom of the box where I could install some thick-sturdy plastic or ceramic piping and have its opening in the upper grill area. I'm sure if designed right, this would perform MUCH better than an AEM CAI.
[Modified by Mike95lude, 11:53 AM 4/10/2002]
Ryanhooligans
Sep 13, 2006 11:25 AM
