need p2t ecu info. and a few itr after swap questions?
Old Apr 26, 2006 | 04:19 PM
louie3252's Avatar
Default need p2t ecu info. and a few itr after swap questions?
Hey i just got done doing and ITR swap in my ek. after it was installed, i ran into the problem that the sohc vtec harness was off a 99, and my cars a 98, needless to say. dash harness are diffent, no tach signal, or cluster functions, and cooked an ecu some how because of it. Im now running a p2t-003 ecu, and all of the connectors plug in (good)(yeaH!) anyways, is p2t-003 jdm>? I dont have a check engine light, and i cannot communicate with the ecu via snap on scanner. so no obd2 codes. also if p2t-003 is jdm>? from 96-98 ek sir? would it look for the 2nd stream o2 sensor, or can i get away with not running one, and no cat, since it is or if it is a jdm ecu? lemme know
Old Apr 26, 2006 | 04:24 PM
louie3252's Avatar
Default Re: need p2t ecu info. and a few itr after swap questions? (louie3252)
just searched and some how found this . and this guys got the same ecu. p2t-003 and someone told him is canadian ? hmm lemme know https://honda-tech.com/zerothread?id=968457
are there diffences in the canadain ecus? are they more similar to jdm>
Diggie
K Series
Aug 9, 2017 10:15 AM
Baller111
Jun 2, 2012 04:01 AM
wunfstgsr
Engine Management and Tuning
18
Aug 9, 2010 07:33 AM
i-VTEC_do_you
11
Dec 31, 2009 08:11 AM
creepy116
Nov 30, 2007 11:24 AM
