How do i get this thing off?
Old Apr 26, 2006 | 11:25 AM
jsk62's Avatar
Default How do i get this thing off? (Main Cap Bridge)
So i spun a bearing and i'm in the process of taking off my rod caps to get to the bearings.
Problem: How do i get the Bearing Cap Bridge (aka-girdle) off so i can access my #2,3 rod caps? I've taken off the 6 bolts that bolt it to the main caps underneath, but the thing is seriously stuck on there. any tips from you engine builders out there?
Old Apr 26, 2006 | 11:27 AM
ninetail
Guest
Posts: n/a
Default Re: How do i get this thing off? (jsk62)
tip.. dont experiment on your type r block...
have a experienced tech next to you if your goin to insist that u know what your doing...
because in the end.. u might just make things works (words from experience)
Old Apr 26, 2006 | 11:28 AM
D's Avatar
D
Dead blow. It's just dowel pinned.
Old Apr 26, 2006 | 11:35 AM
jsk62's Avatar
Default Re: How do i get this thing off? (D)
Thanks for the prompt response D.
TomCat39
Engine Machining & Assembly
18
Feb 24, 2016 09:08 PM
Killersohc
Nov 22, 2005 06:31 PM
HmgLauj69
Mar 21, 2005 11:13 AM
SleepyHF
Apr 19, 2004 12:03 AM
slofu
Aug 8, 2003 01:09 PM
